Answering machine will not pick up correctly. Rings off hook then callers hear "please enter your security code". All settings appear to be normal, its set for 4 rings, you can hear our outgoing message, etc. Any ideas? Customer support will not help, as its an older model.
Could be outgoing message is set to announce only without an anounce only message being recorded. see http://pdfstream.manualsonline.com/8/8c8ae66b-b461-40cb-b213-039e3c56ab64.pdf page 28
Testimonial: "I set announce only to OFF and still rings off hook, and still hear "enter your security code"... re-recorded outgoing message with both my voice and the automated voice and still callers hear "enter your security code"... grrrrrrr"
Are you using DSL on the phone line?
If DSL is in use are you using a line filter on the Answering machine ?
memory is most likely full . hold delete key down for a while. it does this behavior if memory if full
SOURCE: I have just purchased a
did you set and saved the message which you recorded.it is necessary to save.
SOURCE: When someone calls my phone rings 4 times then
You must turn off your internal answering machine. There should be an on and off button somewhere on the main base.
SOURCE: Vtech i6789. Had for several
After reviewing the manual, it appears the answer machine does not have call screening ability. I have included a link where you can download the manual.
http://vt.vtp-media.com/ecp/documents/product_Product/75/UserManual/197/I6789_Manual.pdf
