I have a Audio card aark 24. I recently purchased a Lenovo desktop PC with i3 processor with windows 8 64 bit OS. The audio card could not be placed in the PCI Slot in the CPU. Kindly help me
SOURCE: windows xp 64 bit... where is the driver?
Go to http://www.m-audio.com and select the firewire 410, then select windows xp (64 bit) and make sure that you check the box "Show Beta Versions". There's been a beta driver since 2005 ;-)
SOURCE: PC dosen't play sounds occasionally
heres a suggestion go back to xp service pack 2. service pack is very easy to use and more compatibility than sp3. right now my 10 pc's are all xp sp2 and they have no problems about the sound.hope that helps
CHARCOIS
SOURCE: I need a compatible Sound card software
This should do the trick:
http://www.download.com/C-Media-CMI8738-WDM-Driver-Windows-XP-/3000-2120_4-10495782.html
SOURCE: How to use ISA Slot in PCI Slot
There is an adapter available if you look on computer sites for product purchases, try to google it as there or companies than make such items, might be harder to find as PCI and ISA are older connectors and even AGP is begin phased out an PCI express is the lading connector. Google ISA to PCI adapter and see what you can get your compangies to pruchases from. Your local computer hardware shop might have it call first and ask before driving out there, If you find nothing try calling Tigerdirect as they might have older stock, you never know, If to no avail you will have to try and locate an older Motherboard with the two conncectors on it and run that if possible, or find this certain ISA card you're talking about in PCI. Good luck! :)
