Question about Brookstone iConvert Mini Wand Document and Photo Scanner
The error light will not turn off. I have installed new batteries.
How do I make the error light turn off?
Posted by Bill on
1helpful
2008 Jeep Liberty error code gate on dash and interior light will not turn off got new battery and still doing it
can i buy a comma? says vanna white?? LOL !
ok, the battery drains, so you got a DRAIN, called phantom drain.
or dark current.!!
we use a thing called an AMMETER (DMM) to find all drains, easy
do you have one, want to learn or just wanting wild guessing.
on any 08 liberty, we check the scan tool data.
oops it shows battery low, wow even the PCM sees that.
new batteries do not fix drain.
nor dead alternators.
get it serviced, by a pro. ?
1: charge battery (rested its 12.6vdc )
2: start engine, scan tool shows, what DTC errors (post em')
3: battery voltage is , 13.3, to 15vdc running, if not charge system is faulting.
4: ok all that is ok, i then key off and measure bettery cable neg lug drain current, if 0.010a to 0.040a its ok, if over 0.1 amps its a drain.
we then find the drain cause, ASK? its not hard with a meter.
but i bet all you wanted is a wild guess.
2answers
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
1helpful
Lens error, restart camera camera shuts off
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
1helpful
My digital camera has a lens error
2helpful
Lens error, lens do not open
How to correct the lens error 1114
Just says lens error and wont stop making grinding noise
3helpful
Lens error :0x01110000 That's what it says when
Error message: "Lens error, restart camera" unable to get it to work Have powered on & off several times. Also removed batteries and powered on several times all to no avail.
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
Lens error
Brookstone iConvert Mini Wand Document and Photo Scanner Logo
Top Brookstone Office Equipment & Supplies Experts
Ekse
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
