Dell OptiPlex GX110 PC Desktop Logo
K
Kamal Preet Posted on May 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have created bootable usb disk by following instructions on pendrivelinux.com . But not able to boot in optiplex gx110 window xp pc.Also it is not showing usb drive in boot sequence.
Sacraty
Level 2:
  • Expert 64 Answers
  • Posted on May 02, 2014
Sacraty
Expert
Level 2:
Answers
64
Questions
0
Helped
15543
Points
160
This machine does not support USB boot function. Meaning, you wont be able to do so in this specific machine.
5 Related Answers
Anonymous
  • 78 Answers
  • Posted on Aug 25, 2007
SOURCE: Getting my CPU to support the SSE2 Instruction Set
Hi The SSE2 Instruction set was introduced by Intel in its Pentium 4 range of CPU's. Unfortunatly your pc has a Pentium 3 cpu. The motherboard in your pc does not support the pentium 4 processor. Your only option Im affraid is a new pc
Anonymous
  • 217 Answers
  • Posted on Jun 27, 2008
SOURCE: Missing Drives for Dell Optiplex GX260 PC Desktop Problem
if you don't have the cd with the drivers and utilities, then you can download the drivers online with another computer. (you will need a thumb drive or cd to save it on) you will also need to make sure you know what brand of ethernet card your computer came with. once you get that ethernet card working, you can get online and download the remaining drivers, possibly through windows update. be sure to select custom update, not express, so it will search for the hardware drivers for you.
Anonymous
  • Posted on Jan 06, 2009
SOURCE: FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
Optiplex 150 I get a message error loading operating system
can somebody help out there?
Anonymous
  • 51 Answers
  • Posted on Feb 17, 2009
SOURCE: my dell optiplex gx200 bios can't boot
maybe try taking out the cmos battery located in your case, looks like a small watch battery, that will clear bios settings and start from scratch, if there is no battery then there is a jumper sequence to do this
Anonymous
  • 81 Answers
  • Posted on May 20, 2009
SOURCE: I NEED VGA DRIVER FOR OPTIPLEX GX110, WINDOWS 98
you might be able to get a driver on dells website if not try driver detective at www.drivershq.com
good luck
2answers
Windows xp3 bootable usb iso file
use yumi to create a bootable usb (the first link)
the second link is the iso file
also it is recommended not to use windows XP as your main operating system. If you are using for research or something else then its alright.
YUMI-http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
Win XP SP3 - http://offlineinstallersoft.blogspot.com/2015/03/windows-xp-pro-sp3-iso-download-free.html#.VssLKxjxVxg
there are official links too and also guides.
1helpful
If i download a pc operating system to a usb, do i have to put it in a folder with a specific name so that if i where to install it the pc should recognize it?
If I were you I would just use this http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
It creates a bootable disk drive usb and has many many supported distros from Linux to windows 8. If your using it to boot windows 10 just use the windows 8 option as it worked for me.
I like to know what of window installation repair disk do I need for my Toshiba satellite a85-s1072
In case you dont have a disk you can install windows using a USB flash drive by following these steps:
Step 1- Download ISO image of Windows from: windows.microsoft.com/ website
Step 2: Download YUMI from: www.pendrivelinux.com/yumi-multiboot-usb-creator/ website?
Step 3- Plug in your USB in pc.
Step 4: Run YUMI and follow the on-screen instructions by selecting the appropriate operating system.
Step 5: Give path of the ISO Image and select the USB drive to make boot-able disc
Step 6- Plug in the USB onto the system on which you need to install the windows.
Step 7- Turn on the system.(Change the boot preferences to USB if the system do not automatically start booting from USB).
Step 8- follow the on screen instructions to complete the windows installation. Thanks
WIN XP HOME.TELL ME THAT IM MISSING NTLDR?
You may need to do windows repair or clean install by using following steps:
2helpful
2answers
Asus n50vc won't install windows 7 from USB device
Try bringing up the boot menu (it will say what key to press on the splash screen) and choosing the usb. if that does not work try moving ports.
1helpful
Can I install windows on my dell optiplex gx110 using flash drive(USB)?
I would say yes, as long as you can get it boot from the USB. Check BIOS. Are installing you Win 95, 98, or XP? I ask because the manual has reference to Y2K.
You just want to keep it as a Linux box. Have Fun!
Windows xp boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps
2answers
Boot flash drive
Download the HP Format Tool and install it. Get your boot disk or the downloadable files and copy/extract them to a folder on your HD. Make sure anything on your USB Drive is backed up because we are going to format it...
Open the HP Format Tool
Start/Programs/Hewlett-Packard Company/HP USB Disk Storage Format Tool
It should automatically select your USB Drive.
Select FAT or FAT32 Under File System.
Select Create a DOS startup disk
Select using DOS system files located at and point to the folder containing the boot disk files.
Then click Start
Or you can download Win to flash ,follow the bellow link for details,
For Windows xp
http://www.intowindows.com/bootable-usb/
Or
http://www.makeuseof.com/tag/how-to-create-a-bootable-usb-drive-from-your-windows-cd/
For vista
http://downloadsquad.switched.com/2009/08/27/make-a-bootable-usb-installer-for-windows-xp-vista-7-with-wint/
Hope this helps.
Let me know if you need more information
Thanks.
1helpful
3answers
How can i reformat my asus eee pc1000h if it doesnt have a cd drive?
You can reformat your Asus eePC 100h notebook using an Ubuntu Live USB.Here is how to make one: 1. Download an Ubuntu ISO Disk image from www.ubuntu.com or a debian ISO image file from www.debian.com. 2. You can also use an existing Live CD to create an ISO Disk image with if you have a working PC around.Many free tools exist for creating disk images.I suggest Ashampoo Burning studio or CDBurnerXP.Search for them on google. 3.Get your hands on a working PC that has Windows XP/Vista/7 installed on it. 4. Download the UnetBootIn utility from http://unetbootin.sourceforge.net/unetbootin-windows-latest.exe. 5.The procedure for creating the Disk Image is as follows: (a)Requirements: 1 GB or larger USB drive, formatted as FAT32(most USB drives come formatted as FAT32 by default, but if you need to format it, on Windows, go to My Computer->right click your USB drive->format.
On Windows XP, you must be logged on as an administrator; on Windows Vista and above, you will be prompted for permissions via UAC.
On Windows, the UnetBootIN software looks like this:
Follow the guided prompts on the software to make your Live USB drive, and be careful to select the corrrect linux distribution on the window.
When done, safely remove the flashdrive from the PC and plug it in your Asus eeePC 100h notebook.
Boot up your notebook and press the F2 Key as the system starts up and select the USB flash drive as the first boot device(You can also do the same from the BIOS setup).
When you boot up with the Ubuntu Live USB, select "Try Ubuntu without installing" option to run the Live OS on RAM.
When the system boots up completely, go to System>Administration>Gparted and the Gparted Disk utilitty will run.
From the Gparted menu, select the appropriate partition you want to format or modify.
You can read more on Gparted here.
When you are done partitioning and formating your HDD as you desire, you can also install Windows XP/Vista/7 from a FlashDrive by following the instructions below:
1.Get your hands on a working PC with Windows XP/Vista/7 installed.
2.Download the WinToFlash utility from http://wintoflash.com/download/en/
3.Install the application on the PC.
4.Once you are done,insert a Windows XP CD in the PC's optical disk drive and follow the installation instructions from WinToFlash.
By default, the installation path for Windows XP files on the drive is DRIVE LETTER:/Windows/system32.
See the screenshot below for more details:
You can use the created bootable USB to install Windows XP on your notebook.
For more on WinToFlash, see this link:http://komku.blogspot.com/2009/09/wintoflash-guide-install-windows-xp.html
Have a great time ahead.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
