GE JE1390 Microwave Oven Logo
Question about GE JE1390 Microwave Oven
Why does my JE1390 Microwave oven stop working after a few seconds of running
It will run for a few seconds then stop with the time remaining flashing. If I try to heat up using the "Popcorn" button, it goes a bit longer, then stops flashing the "error" message.
Posted by Catherine Floyd on
Jerry Naidoo
  • 151 Answers
Your magnetron is overheating and needs to be replaced.
Posted on May 04, 2014
Testimonial: "Thank you, so is this something I can do myself, or would be safer to get a repairman to do? I am fairly handy and have fixed lawn equipment and plumbing, but never any appliances."
Time
follow the next steps use the VOM and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
2helpful
Tripping GFI
proceed using the common sense. You must open the microwaves for to see what happen, the coffee produce bad contacts, and reaction from component like short, etc. However the following. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Panasonic genius1300w cuts off after 3 seconds
see this causes and fix it. God bless you
Sensor goes off inside microwave after 10 seconds
Set clock but time goes off
Alarm list says motor rotation and cuts off
My GE Profile JE1390 (Sensor Convection Microwave Oven) is coming on when the door is opened. It will still work once you put food inside and set the timer, but you risk radiating yourself. What might...
Door switches
If one of the door interlock switches is not switching properly or there is a condensation problem on the sensor control panel, either can cause the turntable/light/oven to come on even though the "Starts" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
3helpful
Microwave stops running after 3-5 seconds
hade same problem upper door switch by past it microwave works
Top GE Microwave Ovens Experts
vince
Marvin
Marvin
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
