Question about Samsung SCX 4200 All-In-One Laser Printer
HOW DO I FIX CLSU ERROR IN SAMSUNG SCX- 4725FN ?
How do if fix CLSU error in samsung scx-4725fn?
5 Related Answers
Anonymous
SOURCE: SCX-6320F All-In-One... Problem>>>> locked scanner error
There is a green button just on the top of the paper exit, you just need to pull it, and to shut down the multifunctional and then turn it on again. I don´t know if you already did this, hope this can help you.
Posted on Nov 04, 2008
Joe Fine
  • 628 Answers
SOURCE: SCX 4725FN - pulling in two sheets at a time, and jamming
Try fanning the paper. In conditions of low humidity, the paper will tend to stick together. Also make sure the feed roller is clean. Use a cloth with some alcohol on it and clean the surface of the feed roller.
Posted on Mar 17, 2009
Anonymous
SOURCE: How do you scan with Samsung SCX-4725fn?
Having encountered this issue, I read the manual. The only way I found it to work was to press scan and then choose the application that you want to use. I normally just choose scan to Paint. Then launch Paint on your pc, Go to File and select From Scanner and Camera and your image will appear in Paint. (not the easiest scan method in the world but it works; I have tried selecting the other applications on the scanner menu but haven't had any success.
Posted on Feb 18, 2010
MSM
  • 165 Answers
SOURCE: When trying to print a MSWord doc the samsung scx
try a different driver pcl5 or pclXL or just
re install it
Posted on Feb 24, 2010
mariolands
mariolands
  • 2296 Answers
SOURCE: LSU error SAMSUNG SCX 4725FN
Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge in the machine may be dirty. The mirror motor in the LSU could be bad or needs to be cleaned to spin better. The Laser diode may be faulty.
This is not a user-serviceable issue. You will need to contact Samsung for a service. You can do it online via Samsung website or contact the vendor to see who will they appoint to service the printer to, especially if it is still under warranty.
Posted on Feb 15, 2011
Is the SCX-4725FN compatible with Mac OSX Lion? It works fine with Snow Leopard and earlier versions.
Samsung have only released up to 10.6 at the moment. As per link below there is no supported driver available for 10.7 OSX Lion
http://www.samsung.com/us/support/downloads/SCX-4725FN
Aug 30, 2011 | Samsung SCX-4725FN Printer
DOOR OPEN ERROR MESSAGE SHOWING ON SAMSUNG SCX-4725FN PRINTER BUT THE DOOR IS CLOSED
Hi there remove the cartridge and clean the internal part. Then insert the ink cartridge and try. If you face same problem then reset the Printer and turn off for 5 minutes. Now again turn on and let me know the result.
Jan 21, 2011 | Samsung SCX-4725FN All-In-One Laser...
I HAVE A SAMSUBG SCX-4725fn, and am getting a low heat error
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Jan 03, 2011 | Samsung SCX-4725FN All-In-One Laser...
Printer Samsung - SCX-4725FN. In trying to
you may try uninstall the driver and reinstall the new driver from samsung website. www.samsung.com
it might help to resolved this issue. make sure that after you install the driver do a test print and set the paper size to a4 as default it is set to letter.
May 01, 2010 | Samsung SCX-4725FN All-In-One Laser...
Samsung SCX-4725FN won't power on anymore
It is most likely the mainboard. Could be power supply but if tech said mainboard he is probably correct. You can go to the samsung website or ebay to get the board.
You can also google "samsung scx-4725fn parts and get a list of places that carry them.
May 30, 2009 | Samsung SCX-4725FN All-In-One Laser...
Samsung SCX-4725FN - why won't it scan
You have to scan through your computer printers/scanners area. I had this problem, too, but that seemed to fix it for me.
Nov 23, 2008 | Samsung SCX-4725FN All-In-One Laser...
Two Sided Printing for a Mac computer?
I have the same problem with my Canon ImageRunner 3200
Aug 15, 2008 | Samsung SCX-4725FN All-In-One Laser...
Samsung SCX 4200 All-In-One Laser Printer Logo
101 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
