Question about Sansui 32" TV
DEAD SET SHARP CRT TV - Sansui 32" TV
How do I adjust the vhold on the sharp 32u-s80? My screen is flipping
[PDF]32US60 Operation Manual - Sharp Electronics
files.sharpusa.com/Downloads/.../tel_man_32US60.pdf
Sharp SolarEvery SHARP Color Television set is tuned and adjusted for proper color and ... serious injury to a child or an adult, and serious damage to the equipment.
SHARP 54GS-61S OPERATION MANUAL Pdf Download.
www.manualslib.com > Brands > Sharp Manuals > CRT TV > 54GS-61S
Sharp operation manual color television 32u-s50b (48 pages) .... view the all functions implemented in your TV set demonstration and set the CHILD LOCK. 1.
SHARP 32JF-77H OPERATION MANUAL Pdf Download.
www.manualslib.com > Brands > Sharp Manuals > TV > 32JF-77H
Dec 21, 2015 | Sharp Televison & Video
I HAVE SHARP COMPANY 21 INCHES CRT MY FRIEND TV SET PROBLEM IS SET DEAD IN POWER SUPPLAY TRANSISTER 1886 REPLACED AFTER POWER SUPPLAY IS OK FBT ARCKING THEN IMMEDIATLY SET SWITCH OFF SET IN CIRCUIT R6
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 21, 2014 | Sharp Televison & Video
My TV has dead but not same of the 1st and 2nd time,and the switching regulator has be protected.
The set shuts down after one or more times? It is called shutdown and the set is protecting itself.
Apr 17, 2012 | Sharp Televison & Video
DEAD SET
check the power supply.check the fuse first.
Nov 08, 2010 | Sharp 19R-M100 19" TV
No sound and screen sharp tv 20"
Would you be able to be more specific about the behavior of the set, for example does anything happen at all when powered? ie does the standby light come on? does it try to turn on and then go back to standby? or is the set totally dead?
Thanks
Jul 21, 2010 | Sharp 32C-240 32" TV
Dead set sharp 21v-s300red light only green light bad
chek hout transister hstat voltage 8.2volt drivertfr
Jan 28, 2010 | Sharp 27N-S300 TV
Sharp model 29V- FL250s
ac supply track check this ic ac pals track on resister 240k or470k &diode check this track
Jun 14, 2008 | Sharp 25R-S100 25" TV
Sharp television model 32c241
This is a power supply problem. It may be as simple as a blown fuse or as complex as a problem with overvoltage and overcurrent events within the circuitry of the Horizontal and Hig Voltage sections of the set. If it is a fuse that's simple to replace, the other well that can get kind of involved. In any event I would suggest that you get the set analyzed by a qualified Television repair person.
Sep 21, 2007 | Sharp 32C241 TV
Sharp 27N-S300 TV problems
This could be several things, but most likely a burned loose resistor or bad solder joint. All of which causes an inoperative power supply with the result of having a "dead" set. It would have to be checked out to find the problem. Stargazer
Jan 11, 2007 | Sharp 27N-S300 TV
Sansui 32" TV Logo
51 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
