You have misregistration issue? go to printer's menu in calibration, in adjust registration and press enter. it will check the position of the drums. make it 2-3 times. if the result is the same, remove the drum and clean with some alcohol the drum's contact inside the machine. also clean with a cloth the LED surface, maybe it has some toner on it.
if again you have problem, see if you have any old used yellow drum to check.
