Question about Schlage B60 Series Double SecureKey 5-pin KD
How do I fix a Schlage deadbolt. B60 series will not unlock from the inside unless the key is inserted from the outside
Not able to unlock deadbolt from the inside (handle) unless the key is inserted on the outside. Its a new lock installed on a new door. It works (able to turn it to unlock it) fine with the key inserted.... not turned just inserted on the outside.
Posted by Richard on
Christopher O'Clair
    Problem Solver:
  • 15 Answers
With the door open, remove the interior trim (thumb turn) from the door, and using the key, turn the deadbolt to the locked position. Now re-install the thumb turn, in the locked position, and with the key removed see if you are able to unlock the deadbolt. I suspect that the tailpiece (part that sticks out of the lock cylinder and into the thumb turn) is not in the correct position.
Posted on May 20, 2014
I just installed a Schlage deadbolt. If I lock it from the outside (using the key) it locks fine, but I can't remove the key without unlocking it. Now What?
Hi Winston:
Is it possible to try this:
- pull the lock from the door while leaving the deadbolt in place
- turn the mechanism 180 degrees.
- re-install and give it a try.
Let me know how you progress.
Jun 21, 2015 | Schlage Locks & Locksmithing
New deadbolt notworking?
You have the lever that goes from the key cylinder part of the lock through the striker portion of the locking assembly turned part way, either in the wrong direction or not turned enough in the right direction so if you take the inside portion of the lock off and pull the outside portion out of the door and rotate the lever to its proper position and then put if all back together in the correct sequence it should work properly.
Sep 19, 2014 | Schlage Aged Bronze Grip Handle Entry Set...
Why won't my schlage deadbolt key go to the neutral spot in the lock position to remove the key?
You likely have the lever that goes from the outside portion of the lock through the striker/bolt assembly into the inside portion rotated into an incorrect position when you insert it into the striker/bolt assembly.
Sep 18, 2014 | Locks & Locksmithing
Will a schlage b60 fit in the same holes as a schlage regent deadbolt
I'm not sure what the regent deadbolt is, but if you look at the attached Factorylocks.com youtube video it will show you how to resize a Schalge B60 deadbolt.
Dec 18, 2012 | Locks & Locksmithing
Schlage B62 double sided lock - key will not turn both inside and outside and door is locked. inside, it is at 11:00 o'clock.
Hello. get a can of a penetrating lubricant called WD-40. Squirt a little into both key holes and let it sit for a couple of hours. Then insert the key and work it back and forth. If it is still frozen, repeat the treatment until you break it free. Joe
Oct 08, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
I have a schlage deadbolt, keyed on both inside & outside but neither have any screws to remove. How do I remove the deadbolt?
There should be caps over two screws above and to both sides on the interior key cylinder. Carefully use a pointed tool to pry them out. This will expose the phillips head screws that hold the two halves of the lock together.
Sep 24, 2010 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
I have a Schlage double cylinder deadbolt on security door. If I try to lock/unlock from the inside, it works fine. From the outside, the key turns and turns but the bolt doesn't move. I am trying to...
there are 2 buttons on 1 on either side of inside key slot.. those must be removed... more than likely you will destroy them when removing..under you will find square drive screws or phillips..https://www.schlage.com/en/home/products/B62FFF.html
Oct 15, 2017 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
How do I unmount a schlage keyed deadbolt? There do not appear to be mounting screws on either side of the deadbolt housing.
There should be two hole plugs on the face of the interior deadbolt housing, above the key slot. They must be pryed out to access the screws. Unless it is installed inside out, then the the plugs will be outside. Yes I have seen this before or I wouldn't have mentioned it.
Sep 27, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Schlage B60 Series Double SecureKey 5-pin KD Logo
615 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
