Question about Sharp XL-MP60 Shelf System
XL-MP60 Micro Component System
The CD player plays for a few minutes and then shut itself off and the word protect is seen on the screen. It happens to all CD's?not just on perticular one. this machine isa 2 years old and not used all that often ( no young peopel etc.) The CD'shave been cleaned.
Posted by avis on
  • 1 more comment
  • Bajan Jan 11, 2008
    I have the same problem. The CD player plays for a few minutes and then shut itself off and the word protect is seen on the screen. This machine is 2 years old as well.
  • Jenny_D_69_ Oct 28, 2008
    mine does the exact same thing..
  • Anonymous Oct 30, 2008
    Turn on the unit, play CD or Tuner and it shuts itself down leaving the word "protect" on the screen. In the manual, pg 3 number 14, it says the unit has an attachment plug having overload protection, and to "See Instruction Manual for replacement or resetting of protective device". I've read the manual thoroughly and cannot find out how to specifically reset the overload device. I've cleared the unit like on pg 30, which is supposed to reset the unit but that doesn't work either. I went online to see if there was an updated manual but it's the same.
Anonymous
Email answer I got from Sharp:
I do apologize for the problems you are having with your audio unit. The protect mode
indicator will appear when the unit detects abnormal resistance in your speaker setup. I
recommend removing any additional speaker wire that may be added to the unit to extend the
factory speaker lengths. Also, make sure you have all the factory speakers attached, and all
non-factory speakers removed. Finally, please unplug you unit from he wall for 1 hour after
checking all of the above suggestions to completely reset your unit.
If you are still having issues after doing all of the steps mentioned above, the unit may need
to be evaluated by a Sharp Authorized repair center.
Posted on Nov 02, 2008
Anonymous
Awts the protection mode indicate that there something wrong to your unit maybe the power amplifier has d.c output so the system detect there a d.c voltage on the output of speaker terminal so system wont turn on the unit because it as protect mode because the system detect there a short circuit,
Posted on Dec 08, 2008
Stereo turns on shuts off after few seconds
This is a bad power supply. You have to do some serious work at the component level of the unit to fix it.
Jan 22, 2014 | Sharp Electronics - Xldk257n - Xl-Dk257n...
How to remove the protect mode from sharp xl-mp60 stereo
The unit will go into protection mode when there is a short in the speaker wires or the unit was overloaded. Verify that none of the speaker wire connections are loose at the back of the unit or at each speaker. And verify that none of the wires are making contact with each other.
If it is, then remove the speaker wires and connect them again properly. After disconnection get the speaker wires, unplug the unit for 10 to 15 minutes or more. This will make the overload protection back to normal.
Try this and let me know what happens. I hope this would solve the issue
Thanks
Nov 03, 2011 | Sharp XL-MP60 Shelf System
XL-MP60 Shelf System: stereo shuts down and reads protect...
Hello, the problem of you stereo appliances been shut down was as result of a mechanism jam of the system.
The way you could do this is to open the back cover of the appliances and check for the rubber attached to the motor of the appliances, also check and see if you can adjust the mechanism if it is a disorder manner, it require a careful approach.
This will require a skilled personnel to handle this
May 17, 2010 | Sharp XL-MP60 Shelf System
I have a Sharp XL-MP60. It powers up, shows a
Sometimes got fuses for the speakers check that but if they don´t got it the audio amplifier IC maybe are fried
Jun 11, 2009 | Sharp XL-MP60 Shelf System
GE Spacemaker XL 1800 Micro - " Turns itself off after 2 sec. "
It looks like a component is short-circuited and then it acts to protect. Call a service.
Sep 21, 2017 | GE XL1800 1100 Watts Microwave Oven
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 minutes then turns itself off automatically how do i stop this? My HP laptop keeps shutting itself off after...
Sounds like something to do with a power saving feature either from HP itself or from Windows. It could also be that for some reason your computer is overheating, which it than shuts itself off to protect the processor. I would try playing with your power saving features, and cleaning out the fans.
Mar 13, 2009 | Computers & Internet
Sharp 5 disc cd player
Email i got from Sharp:
Oct 28, 2008 | Sharp XL-MP60 Shelf System
Shelf system shuts after a few minutes philips FW-R7
In power supply check capacitors ,one of them is leake or dry.Best way of detecting this cap is to have freez it (coolant) to sprey on the sections in power supply and thanindividual capacitors this will definately solve your problem.
Dec 16, 2007 | Philips FW-R7 CD Shelf System
PROTECTION
See my post "HT-DB120 - PROTECTION due to shorted output stage "
Jan 02, 2007 | Samsung HT-DB120 System
Sharp XL-MP60 Shelf System Logo
1,065 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
