SOURCE: oki c3400n all 3 lights are flashing amber 2 times a second
i suspect an ouput sensor actuator beeing dislodge in the process of paper removal
SOURCE: My OKI C3400N is printing Y with 2 dots above the
A mere suggestion have you considered uninstalling the printer driver and reinstalling it. . . Are you using the most recent printer driver? Do you have a Virus?
SOURCE: is ther a way to
I believe there is, but it looks like someone may have already suggested a few steps, let me know if anyone has suggested something already and I will definitely help you out here.
Thanks
Tim
SOURCE: se puede resetear el contador de los tambores de
Trata esto:
When installing the C3400n printer, or when replacing the toner
cartridge, be sure to fully insert the toner cartridge into the image
drum, and make sure the blue lever is pushed ALL THE WAY toward the back
of the printer (fully locked position). If it is not fully closed
(locked), a "toner sensor" or "toner empty" message may result. Note:
(Picture at bottom shows incorrect position of locked toner cartridge that may result in either of these messages).
Installation Procedure of Image Drum and Toner Cartridge:
>> Insure the toner is fully locked, see
photo below showing the correct and incorrect positions of the locked
toner cartridge.
CORRECT (Fully rotated to lock position)
INCORRECT (Not fully rotated to lock position)
SOURCE: ineed to install oki c3400n
You can find drivers for all operating systems at the link below. Just select your Windows 7 driver from the pulldown menu:
http://my.okidata.com/pp-C3400n.nsf/openingdrivermenu?OpenFrameSet
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
