Question about Nespresso C190 Espresso Machine
Nespresso FNA2 My Nespresso FNA2 orange light is continually flashing and I cannot use the machine. Would appreciate it if you could help me solve the problem.Thank [email protected]
Posted by barbiet on
1 Related Answer
Anonymous
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
Nespresso latisimo plus 4 lights keep flashing when switch on and just switches off?
Try pressing and holding all four buttons down, then, while still holding the four buttons down, turn the machine on with the power switch. This should return the machine to its factory settings. If you've had the machine for a year or more it may need descaling, but the Cappuccino button usually glows orange when this is necessary. Hope this helps - good luck!
Feb 16, 2015 | Nespresso Coffee Makers & Espresso...
Cappuccino and latte macchiato buttons blinking
The unit is heating the steam - the lights should switch to contant once the right temperature is reached. Make sure to always descale the machine if the cappuccino button light turns orange.
Mar 29, 2014 | De'Longhi Nespresso Lattissima Plus...
Krups FNA2 doesn't draw water!
If it sounds like a pumping noise but louder then it may mean that the pump is bone dry and needs to be primed. You need to find an imaginative way to force water into the socket that the tank engages with. A clear hose of the correct size with water already in it and then press the button and blow into the other end of the pipe. Once the valves are immersed in water it should start to function.
Dec 18, 2013 | Krups Coffee Makers & Espresso Machines
Orange light on delonghi nespresso
Sorry chaps, all these suggestions are wrong. The orange light on the small cappuccino button means the unit needs to be descaled. See Nespresso support to download the user guide and you'll see this explained there
Feb 20, 2013 | Coffee Makers & Espresso Machines
Nespresso u, all the lights are flashing and the pod doesn't release automatically.
The machine has started the "decalcification" process.
When the three lights are flashing just press the three buttons at the same time (with three fingers) and relase when you hear a beep. After that your all good.
This happens when you press the three buttons at the same time when cleaning for example.
Hope it helps!
Oct 28, 2012 | Williams-Sonoma Nespresso U Espresso Maker...
I need to know if the Concept FNA2 41 Nespresso machine is double insulated or not. I am Portable Appliance testing in Queen's University Belfast, and none of the metal parts of the aforementioned is...
here , double insulated machine only have an active and a neutral pin in the power cable
you can test by testing for continuity between the active and the metal and neutral and the metal
if it has a 3 pin plug consider as not double insulated
Sep 11, 2017 | Nespresso C190 Espresso Machine
Small and large cup lights won't stop flashing
Tish3030 response worked PERFECTLY. Thank you, Tish.
Apr 19, 2010 | Nespresso Essenza C100 Espresso...
Blinking orange light on model D290 and it is not full of capsules
I solved this problem by realizing that I had forgotten to insert back a certain piece of plastic, that I had taken out to clean. this caused the blinking light
Jan 04, 2010 | Nespresso Coffee Makers & Espresso...
Inspiron 1200 battery light continually flashing orange
If your battery LED flashes or is solid Yellow or Amber color, this usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 18, 2009 | Dell Inspiron 1200 14.1 XGA LCD...
Aug 20, 2007 | Nespresso C190 Espresso Machine
Nespresso C190 Espresso Machine Logo
148 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Ekse
Colin Stickland
Colin Stickland
NOEL
NOEL
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
