Indow uinit dropping water
Make sure the unit is leaning just a little backwards. If the unit is tilted in, the water will drain out the front.
Also, take the filter out and look at the evaporator coil .(looks like a small radiator)
If it is dirty and stopped up, chances are, the drain just behind the evaporator coil is plugged up. If this is the case, the unit will have to be pulled out, the case will have to be pulled off and the unit will need to be cleaned. If water is used, be careful not to get the motor wet or any other electrical components. Also if you use water, let the unit dry out in the sun for an hour or so.. Good luck I hope this helps you.
