Question about HP Compaq Presario v3000z Notebook
SMART error when i boot up my computer i'm getting a message that says the harddrive is corrupted and failure is immenent. i've ran the diagnostics and i'm getting a #1-04FAIL msg.. is there anything i can do to solve this problem???
Posted by Liampw26 on
Ravi Kumar
  • 186 Answers
If you get Imminent Hard Drive error or SMART error during the POST in the BIOS sequence, it is clear that the Hard Drive of the Notebook is damaged and needs to be replaced.
However, to confirm this, you can check the Hard Drive of the Notebook from the Hard Drive Test utility in the BIOS.
Start or restart the Notebook and start tapping the F10 key which will take you to the BIOS Setup window.
In this, go to the Diagnostics or Tools tab using the Left or Right arrows in which you should find the Hard Drive Self Test utility.
Start the test by selecting the Utility using the Arrow keys and pressing Enter key.
This utility will take around 80 minutes to test the hard drive and if the result is fail, it is clear that the Hard Drive of the Notebook failed and needs to be replaced.
Posted on Sep 15, 2008
John Hechtman
  • 6 Answers
I doubt that re-installing the OS will help. Typically, prompts of drive failure mean just that. The solution is to replace the hard drive and re-install the OS.
Posted on Mar 05, 2008
Anonymous
    Sergeant:
    Champion:
  • 244 Answers
If it is smart error message, you should get new hard drive.
Posted on Jan 19, 2008
  • Anonymous Jan 19, 2008
    if it is smart error message, you should replaced hard drive
arben pllana
  • 1,006 Answers
I think u have to try to RE-install OS
Posted on Nov 03, 2007
Boot mgr error
This message usually means your "boot record" on your harddrive is corrupt due to a virus attack or harddrive failure. You will need to repair your boot record. If that doesn't solve the problem, replace your harddrive. If you don't know what this means, take it to a good computer repair shop. It's not something you want to do as a "newbie".
Oct 13, 2013 | Computers & Internet
Getting error codes 650f:0244, 650f:1A44 & 650f:136C
The errors and Blue screen mean Corrupted files, You need to re install Windows.
Jun 21, 2012 | Dell Computers & Internet
When I restart computer, I get a message saying immenent failure, Hitachi Drive O, Smart??
well, error like that appears when you usually transfer files from one driver to another driver.the message appears before the start up window..but though error appears hard disk will still function..anyway, just to make sure have a back up copy of all your files..
Feb 22, 2011 | Computers & Internet
No harddrive detected, verifying dmi pool data, disk boot failure
Help on making a bootable XP install CD for including storage device drivers (such as SATA drivers that's not included in older XP CDs): http://rapidshare.com/files/211421782/nLite_Instructions_XP.pdf
Follow my brief instructions to make an updated XP CD.
May 15, 2009 | Acer Veriton 7500G PC Desktop
DST result fails
I would say this is the memory. You said that you checked the memory, and it passed, but did you download a cd called 'memtest x86' ? This will definately make sure your RAM isn't cooked. You boot off of this disc and let it go for a couple hours, it will tell you if it finds errors. Also, if it's the harddrive, you can just replace the harddrive, and then hook it up via USB and retrieve your information.
Feb 05, 2009 | Dell Latitude D610 Notebook PC
1720-SMART HARD Drive detects immenent failure. What shall I Do?
Sounds like your hard drive is about to pack up. You can disable SMART for your hard drive in your CMOS setup. which will allow you to boot up your pc. I suggest you back-up all your data as soon as possible before the hard drive fails completely.
Nov 29, 2008 | HP xw6600 Workstation with 650W 80 PLUS...
ACER SMART failure
SMART means self monitoring and reporting tool, this is the option which performs certain test for the status of hard disk health, if its coming it means condition of your hard disk is not good, its better if you immediately back up your data and replace it, by the way you can also disable this warning through the bios, just disable the smart feature in hard disk
Nov 10, 2008 | Acer Aspire 3680 Laptop
When booting my laptop I get the following message: SMART Failure Predicted on Hard Disk 2:WDC WD1600BEUS-22RSTO-(S1) and a WARNING: Immediately backup your data and replace your hard disk drive. A failure...
welcome to fixya
you will need to contact the maker of the computer unless they tell you to take back to best buy ...
i hope this helps you out have a good day
Aug 04, 2008 | Gateway Computers & Internet
Hard Drive detects immenent failure.
If this is a brand new hard drive from a store return it for a new one. Hard drives have a built in feature called SMART. For some reason the SMART function is reading that there is something very wrong with the drive. If you have more than one hard drive installed on the system make sure SMART is detecting it on the new drive and not the older ones by unplugging the other drives from the motherboard.
Aug 11, 2007 | Compaq Presario 5005 (470014-507) PC...
HP Compaq Presario v3000z Notebook Logo
276 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
