Question about Minolta Di3510f Bizhub Copier
C0500 malfunction code c0500
Tareq Bin Mostaq Mostaq
    President:
  • Minolta Master
  • 1,449 Answers
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Posted on Jul 17, 2014
2 Related Answers
babaprithi
Prithi Singh
  • 372 Answers
SOURCE: Minolta EP2080 malfunction detected ...
the laser unit of the machine is faulty.either the polygon motor in the laser unit is not working or the laser diode is not working.anyways u have to replace the laser unit to make it work and it is costly so better buy a new machine
Posted on Aug 16, 2011
Carl
SOURCE: A MALFUNCTION WAS DETECTED - CODE C0500
The dinosaur copier is not connected to the computer as I have a multi-functional printer instead. The Minolta Dialta, model AFR-14, is likely older than I am:)
Posted on Jul 18, 2012
Malfunction code c0500
In minolta copiers the C5xx codes refer to fuser unit malfunctions.Verify the fuser unit gears,the fuserheater lamp continuity and the thermofuses continuity.To reset the codes please the copier model and I tell you the reset method.
Mar 01, 2013 | Konica Minolta Office Equipment & Supplies
C0500 error code
Step 1:
The error code fusing unit heater lamp malfunction.2_4_2013_7_43_37_pm.jpg2_4_2013_7_44_01_pm.jpg
Step 2:
Select the trouble reset and exit.If the error code appire again remove the fusing unit and repair.
Feb 03, 2013 | Minolta DiALTA Di250 All-In-One Laser...
Minolta Dialta Di200 malfunction
1-The C0500 code can be reset following the steps below: find a small
hole on the right side of the control panel. press it using a paper clip
2) When the dot appears on the LCD after reboot, press the number 3 key.
3) The mode will change to the initialization screen.
4) Choose the selection for trouble reset.
5) After reboot the code will be cleared.
good luck
Feb 10, 2010 | Konica Minolta DiALTA Di200 Copier
When i insert a fuserunit immediately the message
This cuuld be the heat hamp or thermo furse need to call for service.
Feb 01, 2010 | Office Equipment & Supplies
C0500 error code
Verify the continuiti of the thermofuse and the heater lamp,cleaning it reset the malfunction codes to open /close the front door or enter in the service code Stop-00-Stop-01,acces 3 after appaire the * in the left side in the touch pannel,reset to trouble icons,press exit and total reset button twice.
Dec 07, 2009 | Konica Minolta DiALTA Di200 Copier
Malfunction detected, code CO500 on our printer, model Di251.
my di2010 has a co500 code on it after someone tried to run a transparency thru it.
Jun 25, 2009 | Minolta Di251 All-In-One Printer
I'm getting a malfunction code C0500
C0500 is a heater failure, the fuser section failed to get to the desired temp in a given period of time.
Try resetting the code, there is a reset switch behind the access panel,at the contrast knob inside the machine.
Hope this helps.
ed
May 04, 2009 | Konica Minolta Office Equipment & Supplies
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Minolta Dialta Copier
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode. Go to "Counter" Go to "Trouble" Trouble reset If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar. You may need to clear the counter by pressing "clear" and then "end". After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!
May 10, 2007 | Konica Minolta DiALTA Di200 Copier
539 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
