Sewing Machines Logo
A
Anonymous Posted on May 01, 2014
I have a whited d'lite w1750c that has a broken spool pin. Can it be replaced?
5 Related Answers
Anonymous
  • 106 Answers
  • Posted on Apr 02, 2008
SOURCE: broken spool spin
www.sewusa.com
You should find what you need, email them if your part is not listed
jpack76645
Jay Pack
  • 23 Answers
  • Posted on May 18, 2009
SOURCE: Spool pin broke off, need replacement. Model No
Try this site: http://www.vaccenterinc.com
or
http://www.sewingmachineparts.net/
Anonymous
  • 1116 Answers
  • Posted on Mar 29, 2010
SOURCE: How do I replace a broken spool pin on the Brother
If the spool pops in, you may be able to find a replacement where sewing machine parts are sold.
If it was a molded to a platform, a thread stand may be a less expensive method to use. You can find a single cone thread stand with sewing notions.
http://www.sewingmachine221sale.bizland.com/store/page24.html/
Anonymous
  • 1788 Answers
  • Posted on Mar 01, 2011
SOURCE: spool pin broken fell into
They are available online for about $4-$5. I saw a metal one for $4. Or go to www.brother-usa.com and order from them.
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Jul 11, 2012
SOURCE: Where can I get replacement spool pin holders for an Elna 7000?
have you tried sewingpartsonline.com
How to remove broken horizontal spool pin of Singer Sewing machine model 6550 and replace with new spool pin?
It appears to be just "hooked" on according to the photo, and you can get the replacement part for $4.00 using this link: http://www.sewingpartsonline.com/spool-pin-singer-3709-sewing-machine.aspx.
However, before you go to all that trouble, you can also just use the auxiliary spool pin used for twin needle sewing which came with your machine but can be purchased from the same site for about the same price.
I don't use either -- I just put the spool in a cup behind the machine and thread from there. See? One way or another, you're back in business!
How do I replace a Broken spool pin
What Make and Model?
One fix would be to jury-rig a spool pin using a wood dowel or metal rod (metal coat hanger piece.) Put it behind where the broken pin is and duct tape it in place. Would look odd but would work.
1helpful
Do not know how to replace spool pin and spool cap
It looks like it might just snap into place. Of course that means you have to remove the broken bits which may require a drill, small bit and needle nose pliers.
How to replace spool pin on model 5160 singer sewing machine
Drill and tap out the broken bit. Put new one in.
2answers
Elna lock overlock 5 thread sewing machine, the thread guide pole is broken and I need to replace
you should be able to buy this part from either a local Dealer who stocks Elna or from online. try www. sewingpartsonline.com or www.sewusa.com
Broken plastic part within which thread spool pin is inserted
You can search for:
Make Model parts diagram
to see what replacement parts are available.
If not, you can probably devise something to improvise. I've used plastic drinking straws as spool pins, or plastic chop sticks.
Top White Sewing Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
