HP LaserJet M4345 MultiFunction Printer Logo
A
Anonymous Posted on May 01, 2014
Error code 49 4c02
How can I clear this code?
2answers
Ricoh 1813. Error code c551
The Ricoh copier error code SC551 / 551 is a fusing thermistor 1 error code.
It can mean:
1. The thermistor is not connected
2. The thermistor connector is bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
Error code H4
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Toshiba studo120 H4 error code
1helpful
2answers
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
1helpful
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
53helpful
6answers
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
10helpful
2answers
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
4helpful
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
processor on the formatter
to abort operation. This type
of error can be caused by
invalid print commands,
corrupt data, or invalid
operations. In some cases,
electrical noise in the cable
can corrupt data during
transmission to the printer.
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
k24674
Grand Canyon Tech
Grand Canyon Tech
