Question about Craig Electronics Craig Micro Cassette Voice Recorder with LED Recording Indicator CR8003
CR8003 TAPE RECORDER
I NEED RECORDING TAPE NUMBER THAT GOES WITH THE CR8003 TAPE RECORDER
Posted by RONALD Matthews on
Javier Gonzalez
  • 207 Answers
Hello may be you try to say what type of tapes used your unit, if yes it is a micro cassette size see link for some available for your unit. http://www.tvps.com/Departments/Dictation-Accessories/Cassette-Tapes/Micro.aspx
Posted on May 07, 2014
How do you connect Sony rcd-w500c to Sony tape deck to record tapes to CDs?
Line Out from the CD player/recorder goes to REC IN on the tape deck
Sep 09, 2014 | Sony RCD-W500C 5-Disc CD Recorder
Why won't answering machine work
Hi Julie,
If yours is a cassette or other type tape recording answering device - check that the tape hasn't broken. If a digital recorder / or cassette tape type, be sure that the recorder isn't full or that you're at the end of the tape. Erase / delete old messages to recapture recording space. If you need more help, please provide the model number of your device.
May 19, 2014 | Panasonic Lands Phones
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Recording
I'm going to venture a guess that what might have happened is you changed the mode of recording. VCRs record in either short play, or long play, or even super long play. As the length of playtime goes up, the quality goes down, because for short play, a 6 hr tape will record only two, whereas a 12 hour tape will record four hours. More information is stored on the tape, so the quality of picture and sound increase, but a longer movie could be cut off. You can adjust the play-length with the sp/slp buttons on your remote control.
Jul 19, 2009 | Toshiba W522 VHS VCR
No sound coming through when recording from hi fi tape to computer
This is actually simple to do. Connect the line out on your tape player to the line in on your computer. Then download a free program, from the net called Audacity at http://audacity.sourceforge.net/. The program is totally free and works great. Some recording studios use this program. In the middle of the main Window on Audacity set it to record from Line in. This is from the small drop down menu next to the little microphone icon. Then hit the record button on Audacity and play your tape. You can record each song individually or you can record the whole side of the tape at once and separate the tracks when you save them. You can even use this program to clean up the sound on your recordings. I have transferred many of my tapes and records to CD using this process. I hope I have been helpful and good luck
Jul 01, 2008 | Genius Soundmaker Value 5.1
Sansui video/dvd player recorder
What is model number of unit? Are you sure it records dvds?
Feb 22, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Panasonic DMR-E55 Won't Let me Record my own VHS
Hi
This is probably caused by an irregular magnetic encoding pattern being generated by the tape itself. If the DVD recorder does not fully recognise the code, it may incorrectly interpret it as copy protected. If there is any tape flutter or there are tape edits, these can contribute to the problem. In addition to this magnetic imprinting can occur on old tapes that have been stored for a number of years without being spooled. basically wrong bits of the tape get magnetised. You can sometimes hear an echo on old tape recordings caused by imprinting.
You could try the following:
1) If available, try using a different video machine to play back and record from.
2) Whatever video machine you use, put your tape in, fully fast forward and rewind a couple of times, then try your recording again. This is particularly important if you haven't used the tape for some time.
3) If it fails again, check to see if it always fails at the same point.
4) If it does, try winding forward a little and then try to resume recording.
5) If you can record it means that a short section of tape is giving a spurious code to your dvd recorder and confusing it.
6) Use a re-recordable dvdrw to make a master. You won't keep wasting discs if the recording stops. You will also be able to produce another dvd from your master and edit it if your recording ends up in a number of segments.
7) Always use the highest quality setting possible when producing a master.
8) If all else fails, if you have a friend with another dvd recorder, maybe try that.
Have fun....
Jan 21, 2008 | Panasonic DMR-E55 DVD Recorder
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
Craig Electronics Craig Micro Cassette Voice Recorder with LED Recording Indicator CR8003 Logo
110 people viewed this question
Top Craig Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Craig Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
