Question about Brother HL-2040 Laser Printer
How do I reset or clear the memory on HL-2040?
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: brother hl 2040 laser printer
On the brother printers, the fuser is often attached to the toner (they come out as one piece). If you look at the old toner, you will probably notice that it is longer than the new one. The extra piece that makes is longer needs to be taken off of the old toner and attached to the new one.
Posted on Nov 12, 2008
jtuminaro
John Tuminaro
  • 56 Answers
SOURCE: want to install software for hl 2040 printer .i lost installation disc
Here is a download for the software:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=hl2040_all
Just select drivers and then your operating system and download the software!
Posted on Jan 15, 2009
Anonymous
  • 90 Answers
SOURCE: Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Reset the drum counter only when you replaced the drum unit with a new one.
Posted on Aug 03, 2009
Anonymous
  • 26 Answers
SOURCE: I need to download the drivers for my Brother HL-2040
There is no Mac driver available for this printer. But you can follow the steps to install your printer for Mac
http://pub.brother.com/pub/com/pdf/macosx/mac105_driver_usb.pdf
Posted on Sep 09, 2009
Testimonial: "Very helpful. The instructions were very clear and to the point. I have my printer working. Thanks very much."
Yuk-Wa Chan
  • 133 Answers
SOURCE: resetting toner cartridge on brother hl 2040
Just push down the blue buttom for 1 min.
after you see 4 lights then it's okie now.
Posted on Sep 14, 2009
How do I clear the printer memory on HL-2040 - delete a job that has been sent and processed?
Unplug your printer. Wait 5 minutes. That should clear any memory in the printer.
Jun 03, 2016 | Brother HL-2040 Laser Printer
My brother HL-2040 wont print and the green ready light is blinking but nothing is happening
Have you tried pressing the GO button to reset the device? I had a similar problem, found this manual and it helped me, check out the troubleshooter ;) Brother HL-2240 manual
Oct 04, 2013 | Brother HL-2040 Laser Printer
I have replaced the fuser on Brother HL-4070cdw but the screen displays fuser unit end How do i clear the message Thank you
Look on page 115 under maintenence. Follow the instructions down to where it says Belt Unit, instead, find Fuser Unit then continue with reset instructions. Hope this helps.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_4040CDN_4040CN_4070CDW_EN_1037.PDF
Oct 27, 2009 | Brother HL-2040 Laser Printer
Where is the toner reset button on the Brother HL-2040?
I think there is none. It will reset when you install a new cartridge.
Oct 04, 2009 | Brother HL-2040 Laser Printer
Resetting the counter for Brother HL 2040
wecan reset brother cartage 2ways. when we are filling at that time we can adjust white ringe of cartage. otherway after reffiling . and when we put cartage in side the printer. we should push white and black point and start the printer .then it wi be reset.(it is tech. private methode)
Jun 11, 2009 | Brother HL-2040 Laser Printer
Ip address for brother 2040
Up to 20 pages per minute
• HQ1200 resolution (up to 2400x600dpi)
• HL-2040: 8MB memory standard
HL-2070N: 16MB memory standard
• 250-sheet input capacity
• USB 2.0 and Parallel interfaces1
• Built-in Ethernet Network Interface1 (HL-2070N)
The 2070 has networking not the 2040, according to the borchure, you would not be able to network this one, only usb and parrallel port. You could do it if you wanted to use a computer as your network printer server. In that case just use your router to select an ip address for that machine and either run it in DMZ if you have a linksys . If you just enable shared printer it should work on all your machines on the network. That's how I did it prior to a 4in1 wireless.
http://www.brother-usa.com/VirData/Content/Printers/ModelBrochures/Brochures_HL2040.pdf
Mar 19, 2009 | Office Equipment & Supplies
Lost Installation CD for my Brother HL-2040 printer
Where Can I download installation software for Brother HL-2040 printer
Sep 13, 2008 | Brother HL-2040 Laser Printer
Brother hl 2040 drum unit assembly installation
I was trying to put it in the wrong side of the printer!
Apr 11, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
Norman  J Weimar Jr
Norman J Weimar Jr
k24674
