SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
A
Anonymous Posted on May 01, 2014
Sweesmp3 player when took of laptop,it wont work
Swees digital mp3 player when took of laptop chargeing,it wont switch on
4 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Dec 28, 2008
SOURCE: my sansa mp3 player won't charge or connect
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Anonymous
  • 36 Answers
  • Posted on Jan 05, 2009
SOURCE: sansa clip mp3 player wont charge
Try to charge it on another computer to determine if it's your computer. If the other computer works, then the problem is with your computer. (If your computer has multiple USB ports, you could also try another one.)
If the other computer does not work, then the problem is likey your cable. If you have another friend with the same device, borrow their cable and try it. If it works, then you need a new cable. If it doesn't work, then your Clip has issues. You could try doing a complete reset on it by sliding the power button up and holding it for 15 seconds (as described in the manual at http://www.sansa.com/sites/default/files/downloads/CLIP_UM_0608_ENG.pdf).
Anonymous
  • 54 Answers
  • Posted on Mar 10, 2009
SOURCE: my computer does not detect my mp3 player sansa 4.0 gb
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
woozie38
  • 608 Answers
  • Posted on Mar 28, 2010
SOURCE: SanDisk Sansa e260 (4 GB) MP3 Player MP3 and
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
1helpful
My mp3 wont turn on unless its connected to charger, i charged it all night last night and this morning i took it to school and it wouldnt turn on. it only turns on when i plug it into charger right when i...
Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
Mp3 wont charge
2answers
One day I got in trouble my dad took it away. Once I get it back a week or two later I put it on my moms laptop to charge but no computers are detecting the device or it wont charge. Can you help me to fix...
first off check the cable your using it might have gotten broken then check the mp3 player and see if theres anything blocking or wrong with the mp3 players charging port
Zen wont work
it sounds like a possible back light problem. those are not something you can fix at home. if you are hearing music etc, mean definetly the back light is gone.
It's like a laptop computer, when the back light gone, you are still able to use the computer on an external monitor but not on the laptop lcd.
My konaki mp4 player wont charge
maybe your mp4 player is switching off... try to turn on...
Mp3 player wont charge or turn on
i have the vl 868 and it would only turn on with the charger in- not when it was unplugged. it took me awhile- you have to turn the switch on and then hold play for like 4-5 seconds for it to turn on.
Mine wont turn on
On the back of the the mp3 player is a reset switch.
Hold that down about 15 seconds.
If that does not work go to the RCA website.
Download the latest firmware.
Plug mp3 player into pc.
Install the new firmware.
Keep it plug to computer for about 1 hour to charge the battery alittle.
Yes YMP40 Mp3 player wont switch on.
I can't open this MP3,what can I do?
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Mohammad Abumuailek
Mohammad Abumuailek
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
