Question about Technics Audio Players & Recorders
Sound barely coming out of the speakers
The sound will barely come out of the speakers.I have checked all connections and they are good. Also when i turn on the Dolby surround or 3 speakers the fan on the back cuts on and gets really loud.
Posted by Samantha Bruton on
Scott Frye
    Genius:
  • 1,175 Answers
What model Technics?
Is there a Tape Monitor Switch or Mute switch on the unit ?..IF so , turn them OFF
Posted on May 27, 2014
5 Related Answers
Anonymous
  • 20 Answers
SOURCE: my jvc rx-6010v is OVERLOADING?
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. (JVC - and others - say SIX ohms, but 8 is the "standard" you should use.) Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: The internal overload protection system you mention is designed to help prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized JVC service center must do this. Note, though, that if you have attempted to "cheat" the system several times, damage CAN be done that requires servicing.] But, before you take the unit in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Posted on Jul 18, 2007
Bruce Bennett
  • 9 Answers
SOURCE: Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Posted on Aug 14, 2007
Anonymous
SOURCE: Speakers pop and rear speakers cut out of surround sound
your problem is a bad solder connection of the relay linked to the lautspeaker sockets. I had the same problem and googled for the solution. Since I resoldered the pins everything is fine. That problem is well known and happens to a lot of Sony receivers.
I can send you a link with a detailed how-to-do solution with pictures, however it's written in german language. But you can use some online translators.
Here is the link: http://www.bmw-syndikat.de/bmwsyndikatforum/topic.asp?TOPIC_ID=28280&FORUM_ID=20&CAT_ID=9&Forum_Title=Geplaudere&Topic_Title=Problem+Sony+STR-DE445
Ralf (from Germany)
Posted on Feb 15, 2009
Anonymous
SOURCE: Onkyo digital reciever has poping noise when in dolby sound
I have the same reciever, and had the same problem.  Contact Onkyo, this is a known issue where defective DSP chips were used and manifest problems with a popping / clicking sound when using surround settings.  These receivers also have a Dolby Digital input issue that can cause audio dropouts when watching cable or SAT broadcasts that encode DD using a 'newer' broadcast encoding methods.  Onkyo is covering the cost of that repair for me now, even though the receiver is 5 years old now....
Posted on Mar 06, 2009
Anonymous
SOURCE: No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Posted on Apr 14, 2009
Radio works but no sound ? confused
Check all speaker wires to make sure they are connected properly, no cracked connectors, no bare speaker wire(s) touching any metal, as this will short out the speakers/ i.e. no sound. I would check the trunk speakers first, from what I have read, it is a common problem on this vehicle.
Oct 04, 2015 | 2005 Nissan Quest
My Logitech computer speakers are playing distorted sound. Also notice that the green power light is dim and wavering.
Could be the outlet, or the power strip if it is on one. would try a new outlet in a different room. return the speakers if this does not work.
May 02, 2011 | Logitech Audio Players & Recorders
I have a problem with the tweeter sound in one of my VR975 Boston speakers. The highs seem to come and go. It is definitely limited to one of the speakers because I can switch cable connections in the...
Register and download the manual for free at retrevo.com'
http://www.retrevo.com/support/Boston-Acoustics-VR965-Speakers-manual/id/522dj380/t/2/
A loose or intermittent cable contact on the OUTSIDE would affect ALL speaker output, not just the high frequencies, and it would probably produce speaker-threatening crackles.
That loose tweeter connection the other guys found isn't fixed. Go back and make them fix it right.
What are your present speaker connection ends if NOT bare wire?
Feb 19, 2011 | Boston Acoustics VR965 Speaker
Speakers and controls are working but sound barely comes out.
Check the back of the computer. Typically this caused when the connection is loose or the speakers are plugged in to the wrong jack. The correct jack on a Dell is usually a light green color. The Microphone is pink, etc.
Jul 15, 2009 | Dell A215 Computer Speakers
Ihave power but no sound
hi bign,
try the following things:
1:Try checking your ground connections, if they are good, then try regrounding the head unit to some bare metal in the dashboard, you could have a problem with the factory ground.
2:try looking at your speaker connections, sounds you have a wire grounding,try disconnecting all speakers and see if it does it. If not, try connecting one at a time, see if you can single out the speaker thats causing the problem
and also check to make sure the speaker terminals are not touching any metal, which is unlikely, because they are factory speakers.
god luck! and please rate this solution!
Feb 13, 2009 | Clarion DXZ375MP CD Player
Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Dec 28, 2008 | Harman Kardon HK695 Computer Speakers
I installed pioneer deh-p6500 in my 1989 dodge ram van. it worked twice, third time i started vehicle, no sound! the display works, all the buttons work but if i turn the volume to max i can barely hear...
it could be the rear wire harness come loose or if you have instellaed it yourself check all of the speaker (+) and (-) are connected and not touching any wrong wire. if still no sound get your radio checked for a burnt amp IC.
Dec 22, 2008 | Car Audio & Video
I have no sound coming from my speakers. Have tried all the troubleshooting option and still have the defect.
1-make sure that digital input source is selected.
2-make sure all audio connecting plugs are pushed in all the way.
3-make sure that polarity of speakers is correct.and the bare wire of cables not in contact with any metal part.
4-make sure that speakers cables not short with each other.
5-check volume and confirm that is not set to low level.
6-check that system is not in mute position.
7-head phone jack is not inserted.
8-repeat your speakers set up and confirm all speakers are on and in good sound level.
Aug 20, 2008 | Audio Players & Recorders
Im having trouble setting up the onkyo surround sound system i bought, i think i have it mostly correct, but there is no sound coming out
2-make sure all audio connections are firmly inserted in.
3-all polarity of speakers is correct and no connection of bare wire with metal part of the receiver.
4-check volume control in good level.
5-check for muting indicator and cancel it.
6-headphone is not connected.
7-check the digital audio output setting on the connected device.and make it on.
Aug 17, 2008 | Onkyo Audio Players & Recorders
Connecting X-540 speakers
Green is the speaker out let.
Make sure the sound card is activated.
Dec 26, 2007 | Logitech X-540 Computer Speakers
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
