If the 380 is listed, there will be additional information there ... if it is not listed, you are probably out of luck using this printer with your nedw OS.
It's compatible, If i am right, you haven't downloaded or installed the drivers for windows 7. If you need, you can download it from here..
1. Hp deskjet d1400 win 7 32bit
Download the appropriate drivers for your system and install it, it'll work fine..
If you have problem please let me know..
[please uninstall the installed driver before you install the new drivers]
Good luck
Installation Also note once you get the driver if you are using a USB cable to connect it to the PC, that you install it like this:
1. Make sure the USB cable is not connected to the PC but connected to the Printer 2. Install the driver 3. When prompted then plug the USB cable into the USB port on the PC to complete the installation process.
When you plug in the printer, it will auto install a driver available from the net, it might not have the features of your current driver but it will make it work.
Fuser unit malfunction code.Verify the fuser heatre lamp continuity,clean and check the thermistors and thermofuse continuity.Open the front door,press the service reset button close the front door.
