SOURCE: Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
SOURCE: setup samsung clx 3170 on shared network
yes
if u use wireless printer u receive n send document via that printer.
SOURCE: can not find the imaging
Please have a look at the links below; each includes a short video to help explain the process. You should order an imaging unit to have on hand for replacement. At the end are included the product number for your consumables. Suggest you find a local supplier or seacrh on-line for a competive price or you can opt to puchase directly from Samsung.
How to replace the imaging unit on CLX-3170FN
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?AT_ID=210811&PROD_ID=1093&PG_ID=-1&PROD_SUB_ID=0
How to redistribute toner
http://www.samsung.com/au/support/howtoguide/supportHowToGuidePopup.do?howto_guide_seq=2632&prd_ia_cd=06010100&map_seq=20418®Dt=20091028182505&page_gb=D&model_name=CLX-3170FN&type_ia_cd=06010000&subtype_ia_cd=06010500&row_index=
What to do when toner is empty on CLX-3170FN
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=41&PG_ID=0&AT_ID=210821&PROD_SUB_ID=0&PROD_ID=1093&EMAIL_ID=41
I could not find information specific to your model on the proper relacements for the imaging unit and toner cartridges; however, I was able to find a statement that the CLX-3170FN and CLX-3175FN are the same printer the main difference is just the colour of the unit. They should therefore use the same imaging unit and toner cartridges which I have listed below:
CLT-M409S Magenta
CLT-C409S Cyan
CLT-K409S Black
CLT-R409 Imaging Unit
CLT-W409 Waste Toner Collector
CLT-Y409S Yellow
Trust this is helpful. Please vote.
SOURCE: I need to downgrade to previous firmware for
Unfortunately, once you install a firmware upgrade it is permanent. Driver updates can be reversed but not firmware. That is why you should always have a definite reason for upgrading the firmware.
