I put the cloths in add the detergent stuff like I always do when the washing machine was finished I open the door and water pours out long story Short the water isn't getting pumped out how do I fix it
SOURCE: Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
SOURCE: Maytag Neptune Front Loader washing machine - door won't lock
It won't spin because the door won't lock. The door won't lock because the door lock mechanism is bad. I ran into this many times with the Neptune's when I was working for Sears. It is not a very easy fix. It is a pain to get to that door lock and replace it. You will most likely need a repair person to come out and fix it. I hope this helps you, sorry to be the bearer of bad news. I hope you have a good rest of the weekend though and let me know if you have any other questions. Good luck.
SOURCE: Front loader door will not open after a washing cycle is finished
call the repair man it is a comp. issue
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
