Question about Apple iPhone (16 GB) Smartphone
The ringer icon keeps appearing on my iPad - Apple iPhone (16 GB) Smartphone
1 Related Answer
a7878
  • 502 Answers
SOURCE: the ringer icon keeps appearing on the screen
Sorry but your Ringer switch needs replacement. Take it to the apple store and see if they'll give you a replacement. If they don't there are third party iPhone Repair Services that can fix it for you. There are also free iPhone Repair guide that show you how to fix it yourself.
Posted on Jul 10, 2010
How do I Delete contact from Skype? I use IPad
http://community.skype.com/t5/iOS...iPad/Deleting-contacts-in-Ipad.../517823
    1)Open skype
    2)On right side tap skype contact, all contact icon appear
    3)Touch and hold the icon you want to delete until a X appears at the left upper corner of icon.
    4)Tap the X to delete the icon. Then tap the cancel button at the right upper corner after finish.
Mar 21, 2015 | Computers & Internet
When I turn on my iPad the ringer appears and I can't access any thing
Hi, I think you need to do a hard restart. Press the round button on the front of your device whilst also pressing the on/off switch at the top right hand edge. Hold both down until the apple appears. This will not harm your device.
Jan 19, 2015 | Apple iPad 64 GB WiFi
How do I remove all my picture files from my iPad
Open the "photo" folder, and hold your finger down over one icon, and keep it down until the icon "wiggles", and an 'X' appears over the icon. Release your finger, and push the 'X' to delete. Or, push the "home" button, if you do NOT want to delete anything.
Oct 31, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Delete an icon on iPad 2
You cannot delete the native mail application.
You can jailbreak your device and use app hider to keep the plastic image from appearing on the springboard, but the application will still be resident.
Apr 15, 2014 | Apple iPad2 WiFi 64GB
Ipad 2 has a transparent line moving across screen
have you tried a hard ware reset?
turn off device, then hold the power button on top and the home key (make sure its not plugged in also)
keep Holding both keys... you will see the apple logo appear, and then flash off, and then it will restart again. If you keep holding the home key and the power key, it will continue in this loop. Holding it until it reboots once should be enough though, then just turn it on and let it boot normally.
Your settings and everything should remain the same, this just will reset the hardware on the device. I have had issues with my iPad 2 with games lately, mainly random crashing, when I do this hardware reset, it usually fixes my crashing issue for a while.
Once again the steps are:
Shut off device, make sure it is unplugged
Hold the Power button and home key, until the apple icon appears and then flashes off.
Let the device turn on normally, let go of home key and hold the power button till the apple icon appears, and let it boot up normally.
Test the application, this may or may not work. But its def worth a try.
Mar 07, 2014 | Apple iPad Tablets & eReaders
How to delete from ipad
Press and "hold" the icon on the iPad until it starts to "wiggle" and the 'X' will appear. Then, you can choose to delete the icon.
Jan 19, 2014 | Tablets & eReaders
Forgtton unlock code on ipad2
hard reset the device
OK, you have noticed the strange behavior of your iPad / iPad 2 or even new iPad 3. It tends to freeze for about a few seconds every minute or is running too slow or something else. This is probably the best time for the hard reset of the tablet. To make things easy follow simple sequence:
  1. Make sure your iPad /iPad 2 / iPad 3 battery is charged above 20% (we would recommend at least 50 - 60 %). If you are not sure charge you tablet for at least 40 minutes.
  2. Make sure your Apple tablet is in Power On state.
  3. Watching the shining screen of iconic tablet with apps' icons on it press and hold down the Wake/Sleep and the Home buttons simultaneously, ignore the red slide "to power off", just keep both buttons holding until the Apple logo appears. This logo is the signal that the hard reset has succeeded. Be patient, some times the hard restart of iPad may take up to 10 - 15 minutes. But such a long restart is a rare case.
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
Jun 19, 2012 | Tablets & eReaders
Unable to access some apps installed on my iPad because no icon shows up on the iPad for these apps
When you exceed your allowed pages for apps,they will still install,but app cannot be created for lack of pages.You can get more room by grouping similar apps into 1 folder to make space.You can also use search function to fill any app installed.Scroll all pages to right until keyboard appears,then type name of app,it will appear in dropdown list.
Please Rate
Apr 02, 2012 | Apple iPad 2 MC770LLA Tablet
The ringer icon keeps appearing on the screen
Apr 13, 2010 | Apple iPhone 3G
My iphone keeps buzzing and shows an icon of the ringer with a slash thru it it wont actually ring, just vibrates altho the ringer is on
"An icon of the ringer with a slash through it"?....Usually that means that the ringer is OFF.If you're sure that the ringer is in fact ON , then check your profile.If it's in the Silent or Meeting profile, the ringer is switched off by default and it goes to vibrate.
Jan 09, 2010 | Cell Phones
Apple iPhone (16 GB) Smartphone Logo
1,453 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
