Question about Indesit W 123 Front Load Washer
Wont finish hi i have put new bearings in my wil123 and now when i put it on a wash it wont finish it will fill up with water and then nothing will happen until i turn it to a rinse a spin . it willthen empty as normal
Posted by irelch1 on
Anonymous
    Scholar:
  • 97 Answers
Did you re-fit the belt? if you did it could be a fault with the motor brushes.
REMEMBER TO SWITCH OFF THE POWER BEORE CHECKING :)
Posted on Nov 07, 2007
How to repair a new washes etw4400 when it fills with water and nothing else happens
You will have to drain the water first by putting your drain hose into a bucket, out a door, etc, or use a shopvac (take clothes out first). This washer has a broken agitator belt. If it is new, call a repairman as should be under warranty.
Jun 16, 2012 | Estate ETW4400VQ Top Load Washer
My indesit WIL123 stopped mid-wash with LEDs 3 & 4 flashing with the main button. Pushed the main off button on the machine and it started to fill with water again. Now have a washing machine full of...
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 22, 2011 | Washing Machines
Tub does not fill, it cycles through to finish no H2O in tub , but on ground. no error code
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 21, 2011 | Washing Machines
Washinging machine tub fills with water after finishing a load
Your problem is kinda the opposite of these tips...
your fill valve has dirt in it and is leaking by...
heatman101
Sep 18, 2010 | Whirlpool Washing Machines
Washer wont fill
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
WASHER WILL FILL WITH WATER, BUT WILL NOT DRAIN
the bearings are bad if it is an older unit you are better off buying a new one
Oct 04, 2009 | Washing Machines
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Indesit W 123 Front Load Washer Logo
114 people viewed this question
Top Indesit Washing Machines Experts
peter gittos
peter gittos
Marvin
Marvin
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
