SOURCE: My blades are dull and will not cut the paper. The
When I bought my last shredder it came with a small bottle of oil. The instructions said to put a few drops of oil on the blades now and then.
I think the oil was actually canola oil.
Read your manual to see if it suggests any lubrication.
SOURCE: Our Royal 15 mx cross cut shredder will back out
Does it sound like the motor is running forward or is it just "dead" when you try to shred paper..... if the motor is running.....then its a gear...but most likely you have lost the pcb in the machine...give Royal a call at 1-800-524-0799 for info on parts and prices.
SOURCE: BLADES LOCK UP/JAM ON ROYAL 9X HEAVY DUTY CROSS
Have you "oiled" the machine.... put some shredder oil on a piece of paper and shred it....do this a few times to get oil into the cutting blades and see if that helps.
SOURCE: royal 1200mx confetti cut shredder : wont turn on
If its dead...no lights, nothing, then the pcb inside has probably gone. Give Royal a call at 1-800-524-0799 for parts and prices.
SOURCE: MY ROYAL CROSS CUT SHREDDER
Most likely broken plastic gear inside...open it up to see which one then contact Royal at 1-800-524-0799 for parts assistance.
