Question about KitchenAid KGST307 Gas Kitchen Range
Control panel KGST307 not lighting up - KitchenAid KGST307 Gas Kitchen Range
Hi, I have Kitchenaid gas stove. the control panel shows the error code F2/E1.. What should I do to fix that?
Most of your F2 errors on stoves has to do with a stuck key. Use a hair dryer or a hot dish towel to warm up the keypad to loosen up that stuck key.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 31, 2011 | KitchenAid KGST307 Gas Kitchen Range
Burner won't light - you don't hear the click to ignite. Gas is flowing, I can light it with a match. I had spilled something down the front and am wondering if that did something.
The control knobs have an integrated switch in them that tells the ignitor to start firing...you could try to obtain some contact cleaner and clean the controls to see if this fixes the problem
Jan 18, 2011 | KitchenAid KGST307 Gas Kitchen Range
Control panel black -No display
no reset fuse inside, by the power cord, also lcd display might be gone hope i helped
Jul 20, 2009 | KitchenAid KGST307 Gas Kitchen Range
KGST307 gas stove has a temperature control problem.
the least expensive fix would be to buy an oven thermometer and note what setting is needed to attain 350 degrees and go from there. please rate me
Jan 06, 2009 | KitchenAid KGST307 Gas Kitchen Range
Hey,
I had this problem once and I just reached through the vent on the front with a knife and turned the locking mechanism. I eventually had to have the range repaired for self-cleaning mode, but this should at least let you get the door open!
Jul 09, 2008 | KitchenAid KGST307 Gas Kitchen Range
Buttons don't work [7, 9 & Start]
make sure the unit is not control locked, usually holding start for 5 seconds activates this, most kitchenaids contain a lock symbol on control panel so hold that if you have it.
if its not control locked and not in sabbath mode (sometimes this is a SAB or to some looks like 5A6 on control panel) holding clock pad for 5 seconds activates and deactivates this same as start does with control lock
when you order the part you want to replace the part called Clock AKA PCB AKA ECB, these are the three most common names, the control panel is the decorative cover
May 02, 2008 | KitchenAid KGST307 Gas Kitchen Range
go to www.reliableparts.com
you can purchase the part. as far as replacing it, i wouldn't recommend it if you have never done it before. some boards require to have some electrical experience and need to be replaced a certain way. have a technician do it.
Apr 25, 2008 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KGST307
can you tell me the complete model # off the stove? i will try and find the parts instructions for you.
Jan 12, 2008 | KitchenAid KGST307 Gas Kitchen Range
F1:E3 KGST307 free standing stove
there is no way to reset the control. you have to replace it. sounds the the jumpers on the board have failed.
Dec 22, 2007 | KitchenAid KGST307 Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KGST307 Gas Kitchen Range Logo
102 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
