Question about Bosch Measuring Tools & Sensors
Why cant I open Bosch trimmer head - Bosch Measuring Tools & Sensors
How do I get the trimmer head open?
Turn the knob in the middle of the head anti clockwise and the string reel should come out.
Aug 21, 2015 | Garden
I have a Bosch hedge trimmer AHS 52 LI and yesterday when I tried to fit the battery to the trimmer it would not fit
Make sure that you are using the right battery, positioning it right to match how it goes the receptacle. Last thing is do not be afraid to give it a good push in there. New ones in particular have a firm seating which can take a little bit to get it in.
Feb 20, 2015 | Bosch AHS 52 Li Cordless Hedge Trimmer
How to open a Bosch AHS 4-16 Hedge Trimmer ?
Not sure how to open it - if engine runs but clutch doesn't engage on revving perhaps the clutch has seized... point to bear in mind though is if you can't open the gear box (don't know how to) you most certainly won't be able to change a part inside - you will just get fiddly bits everywhere and never get them back where they should be - best get a pro to give you their opinion on whether it is worth the cost of getting it fixed.
Sep 22, 2014 | Bosch Ahs4-16 42Cm 390W Electric...
My Bosch AHS 45 16 electric hedge trimmer start, is there anything you can suggest?
Hi Dan Walsh, When an electric motor won't start, it could be an open temperature device in the winding of the motor itself. If you have brushes and they are worn, then one or maybe two of the brushes can't stay inside the brush holder. They are spring loaded and if worn out can pop out. Also, if the winding are open, then there is not continuity. This will cause the condition you described. Not the best news, but it might answer your question.
Good Luck!
Jun 03, 2014 | Bosch AHS 45-16 Electric Hedge Trimmer
Need new head
Mole grips your best bet
Sep 06, 2009 | Troy Bilt Tb70ss Gas Trimmer
How to change blades
Use a large pair of pliers to hold the turning metal ring above the T35 trimmer head. I used a medium-sized pair of Channel Lock pliers. Then, turn the trimmer head counter-clockwise and it should unscrew from the mount. There's no need to open the trimmer head for this operation. Then, follow the parts diagram in the trimmer user manual to install the blade parts in the right order.
Mar 16, 2009 | Husqvarna Garden
Measuring Tools & Sensors Logo
Top Bosch Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Bosch Measuring Tool and Sensor Expert? Answer questions, earn points and help others
