LG 37LP1D 37 in. LCD Television Logo
Question about LG 37LP1D 37 in. LCD Television
How to get cc on lg 42" - LG 37LP1D 37 in. LCD Television
Lg lcd subtitles are very tiny and i cannot read them..how could i enlarge them ?
Use ur tv remote.The remote have a button that said CC pushes that CC button a couples times for cycling more captioning-( Subtitles) words fonts display like CC 2,3.. the words should be bolder and bigger when it is going into with a different fonts setting.Or going the ur tv menu setting itself just change the close captioning fonts in different sizes or thickness and boldness.
I am hard of hearing. Is there a jack in the back that I could hook a head set to? Please tell me where it is if there is one
Yes,there is one read the back tv have labling for a ear phone socket connection.Read ur tv owner manual for exactly where it is located.Why don't u used tv Closed Captioning functions like word scrolling on the tv screen for u to read it.A remote should have a button on it lable like CC button.Push that CC button a couple time u will get CC1,2,3.. u will get scrolling down as Closed Captioning words on the tv screen to u to read.
1helpful
How can i play english subtitles in my tv lg 42 inches
If the signal is from a digital source with multiple language options, then press Menu and go to Option (with the up/down arrows). Press the right arrow button and go to Caption Text. Press the right arrow button and use the up/down arrows to select English. Press Exit or Menu to save and either return to TV viewing or the previous menu.
Otherwise, you will be limited turning on the captions with the CC button and viewing the captions available with the video feed.
For some sources (DVD, satellite), you may need to change the caption options on that unit. See the appropriate manual for the device.
I hope this helps.
My closed captioning is on and I need to know ow to turn it off
U have a CC button on the remote.Use that button keep pressing turn all CC 1,2,3 to off will stop all captioning.
Model: LG 42LC7D Closed caption/text option is "greyed" out and I am unable to use this option. How do I fix this?
If your using the RGB inputs or A/V inputs I do believe that feature is disabled. You have to use the closed caption capabilities with the cable box or satellite from with-in them, which ever you may have. The CC is only active in the menu when cable is directly connected to the RF jack for input on the TV, which can be the cable box also. Hope this helped.
6helpful
Black box appears in middle of screen
go into the menu and look at the closed caption option----if TEXT is highlighted--this is your problem---select CC! or if it has it OFF.The TEXT will only appear on certain channels and it most likely was activated by someone changing the closed caption options. If this has been helpful give me a vote to let me know.
Vizio 42" LCD. Flat screen. Won't display CC on setup screen using HDMI input. Have a Sharp tv on another Directv box and it shows CC via HDMI connection. Problem with receiver or with TV? Costco's "Help"...
CC is a feature of the TV. All TVs are different in features and the Vizio is limited on its features due to cost. To eliminate the directv receiver connected to Vizio TV just swap with the receiver connected to Sharp TV and see if CC is displayed.
16helpful
I have a LG plasma T.V., model 42PB4D. Black box/middle of screen
Try this:
In the menu go to CC and set the TV to CC1 as this is a text box appearing for captions. Hope this works!
Removal instructions for close caption
If you are hooked up to a cable receiver, the closed caption must be disabled in the cable receiver. With most cable receivers the closed caption must either be on or off and there is not cc button on the remote.
Marvin
Marvin
