Volume icon appears spontaneously in mid screen. It goes away temporarily when I depress volume control quickly, but then reappears. Happens most often while using iPad as a reader but that is not an absolute.Please help me find a solution to its removal. Pressing the volume control has an effect for 2-3 minutes. Airplane use control does nothing.
Do you have a case on the iPad? Sometimes an ill-fitting case can trigger the buttons by itself. If there is any lint or dirt between the case and the iPad, it can cause the same issue. If you have headphones with a volume controller on the cable - check that that is not being pressed by accident. You can also check to see if there is any lint caught inside the headphone hole. Sometimes that can cause a little electrical short and trigger funny behavior on the iPad. If none of those solve your problem, take it to the apple store, it could just be a faulty switch.
Any bluetooth iPad keyboard will fix this problem instantly. This is a design flaw and buying a device that can control the volume will be your only option.
SOURCE: How can I improve the battery life of my new iPad? Please help!
Here are two articles that should help you:
http://howto.cnet.com/8301-11310_39-20088870-285/10-ways-to-improve-ipad-battery-life/
http://howto.wired.com/wiki/Improve_Your_iPad's_Battery_Life
Testimonial: "Thanks buddy!"
SOURCE: iPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
SOURCE: Unable to access some apps installed on my iPad because no icon shows up on the iPad for these apps
When you exceed your allowed pages for apps,they will still install,but app cannot be created for lack of pages.You can get more room by grouping similar apps into 1 folder to make space.You can also use search function to fill any app installed.Scroll all pages to right until keyboard appears,then type name of app,it will appear in dropdown list.
Please Rate
SOURCE: I have a Apple IPad 2. I want to remove a home screen Icon, how do I do this?
press and hold down the icon until you see it shaking and an x next to it then press the x and delete.
Testimonial: "I got a good response for my request for help with my home screen. I now know I need to bring it in to a shop since I tried the suggestion and it did not work. Problem is with my IPad. Thanks"
