1999 Jeep Grand Cherokee Logo
A
Anonymous Posted on Nov 27, 2017
Makes high pitch whistle
I have had a anoying whistle noise sounds like its coming from my front driver side tire or motor. I have had tis for a year now, nobody can tell me wha it is. I know its not the tires, because i got new tires,it only happens when im moving, never have the sound at an idle. the noise gets louder and higher the faster i go.
Bill Boyd
Level 3:
Top Expert:
  • Jeep Master 53,816 Answers
  • Posted on Nov 27, 2017
Bill Boyd
Jeep Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949641
Points
172802
Indicates wind turbulence noise
possible around rear view mirrors , weather shields , door edge , bonnet edge , headlights
trial and error is to place tape over adjoining edges to see where a placed tape stops the noise
5 Related Answers
Anonymous
  • Posted on Sep 08, 2009
SOURCE: 2002 Jeep Grand Cherokee Laredo - whining noise driver's side
checked the wheel bearings and sometimes the clips will rub the rotors
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Oct 29, 2009
SOURCE: I have a 99 Grand Cherokee with a high pitched
defective pinion bearing?
Anonymous
  • 53 Answers
  • Posted on Dec 20, 2009
SOURCE: roaring noise form front tire
How do you know the front tires aren't pulling? That's the first thing we need to know. 2nd does this roar happen when in 2wd? or just in 4wd? and is it 4wd part time? full time? or 4low? Does it do it all speeds? Mileage also would be helpful and when did this start?
Anonymous
  • 677 Answers
  • Posted on Jan 09, 2010
SOURCE: whistling from engine
This is a symptom of the inlet manifold gasket having a leak.The whistling is air going in through the small leak/hole in the gasket.With the throttle butterfly shut,air is getting sucked in the only way it can.Try tightening the inlet manifold bolts 1st.But more than likely the gasket needs replacing.Hope this helps
John Hermes
  • 135 Answers
  • Posted on Jan 11, 2010
SOURCE: 97 jeep grand cherokee, strange pop\clunk sound
Check the front stabilizer bar and the bushings on it. It is located under the radiator with arms that bend back to each front tire.
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Sounds like air is shooting out when accelerating. Could this be an exhaust leak? Plugs, coils, hoses seem fine. Noise is coming from passenger side under engine sounds like.
yes could very well be an exhaust leak.but that should be kinda loud and annoying..also u could have a slight whistling sound coming from ur air intake hose coming from air cleaner box to ur intake or throttle body or ur air inlet goin to the motor. when the motor is accelerated it would produce a high pitch sound like a whistling .hope this can help
1helpful
2answers
2011 Avalon high pitched whistle
I had that , and it was the transmission low on oil. Hope this helps.
At high speeds, I here a high pitched squeal coming from the passenger side dashboard. Its like the wind is reflrcting off something and it makes this annoying sound. Can you help me figure this out.
I'd check the passenger side mirror first, make sure it is tight to the window frame, no gaps. It causes a wind noise or whistle. It could be from the outside of the truck, try to pin point. Does noise go away with either window down? Does noise get louder turning in one direction (wheel bearing)? Does it get worse then seem better (could be tire noise)? Eliminate fan motor, and radio. Does it get worse with vehicle speed or just engine speed?
Metal on metal sounding clicking noise while the wheels are turning but only on the frot driver and passenger wheels. What is going on? It started out only on the passenger side and then after the tire...
Is the noise a screeching high pitch or a growling low pitch?
It sounds to me that the CV joints might be bad and you need brakes.
high pitch would be the brake warning tabs
the low pitch would be the brake pads are gone and you are on the rotors gringing away metal
2answers
High pitched whistle noise coming from engine
it sounds to me like it is a blower motor not the engine.(heater fan)
1helpful
2answers
Screeching noise coming from driver side tire
The high pitch sound may come from the brake pads as metal parts hit the disc to signal the owner that it needs change. The metal parts gets exposed when the pads have worn out. The brake also has a hub to cover the disc. See if the metal plate is hitting it but this issue would appear when the wheels are in motion. Check if it is the belts, have the tension checked out. Other than that the bearings are the other items on your wheel that could cause a high pitched sound when you car is in motion.
2answers
My car is making a whisling sound when started.
hi ,,two things 1- water pump. but most likely check your pulleys they will make that high pitch noise one of them fixing to go bad and what will happen the belt will jam and jump lose and will lose all power ,,cause you have one belt for alt and the water pump mostly its the pulley right under the alt ,,hope this will help ....Joe
Whistleing sound on golf gt tdi
It's probably the turbo you're hearing. They spin very fast and make a noise like that. Ever hear an 18-wheeler go by you and accelerate and they make that high-pitched whistle? That's the turbo spooling up. Now, if it sounds like a dentist's drill, that's usually a sign that the turbo is failing, but I'd bet that since your car is under four years old, as long as you've kept up on the maintenance, it's the normal turbo spool.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
