Question about Sony Bravia KDL-37M4000 37 in. LCD HDTV
37m4000 green light - Sony Bravia KDL-37M4000 37 in. LCD HDTV
Please assist with black screen with audio.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 27, 2015 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
My tv when on turns red blinks six times and off
Not sure if you can see this, but I have a KDL46XBR5 and this is the self diagnostic function listed in the service manual.
Six red blinking lights, pause, six more lights may indicate a faulty backlight or a problem related to your backlight. This doesn't necessarily mean you have to replace anything, could be a ground screw is loose, or one of the many cable connectors need to be reseated while the unit is off. See attached to see if this helps.
If not, google "self diagnostic function kdl-37m4000" and see if that helps. At least this should point you in the right direction
Mar 24, 2013 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Sony Bravia KDL-37M4000 37 in. HDTV LCD TV will not turn on
Check its main power regulator section circuit. Replace the power regulator board if necessary. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs.
Aug 18, 2012 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Tv turns off after playing 15-20 minutes, then it will shut down more often. the timer/pic. off button flashes six times. thank You.
6 times power/ standby light blink error shows problem of back light inverter board in your Sony KDL-37M4000 tv as per mentioned in related service manual.
Check back light inverter board to fix the issue.
Thanks.
Jun 17, 2010 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Lightning strike to a Sony Bravia KDL-37m4000
Check if all the PCB board intack.Might worth repairing.
Sep 10, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Will KDL-37M4000 decode PAL signals in the RCA input? I have a WII and want to know if it will work.
PAL will not work in the US or Canada.Only NTSC work with these countries.Check if u have the PAL/NTSC option in ur menu.
Jul 21, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Power supply tv
Only between exact same models. Even then some models have several different versions depending on type of LCD panel used. If you have another power supply from the same model and all the plugs are the same you should be fine.
Jan 30, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Sony Bravia KDL-37M4000 37 in. LCD HDTV Logo
21 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
