Question about Brother MFC-7820N Laser Printer
Brother mfc-7360n printer prints spots all over the page. why is this happenening
My brother mfc-7360n whenever it prints a page the page itself is covered with black spots. help!
5 Related Answers
Meph1234
  • 46 Answers
SOURCE: Help with Brother MFC-8500 all in one printer
When you get the paper, can you smear the print with your fingers, or is printed on there properly.
if you can smear it, it would be your fuser not doing its job properly, if you cant, then its your replacement toner as it most likely incorporates the drum in it, which i think is your problem.
Posted on Jun 20, 2008
Anonymous
SOURCE: brother mfc 465cn printer
If you remove the empty cartridge, you will see a small window on the egde that plugs into the printer, in the center. This is where the printer optically scans for ink levels. On the empty color cart, you can try covering that raised spline with electrical tape or by coloring it with a black permanent marker. That should fool the sensor into thinking your ink is full.
Posted on Jan 03, 2009
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: brother MFC-7420 prints black pages
The drum is defective. The cleaning blade has failed.
Posted on Jan 31, 2009
Yuk-Wa Chan
  • 133 Answers
SOURCE: Brother MFC 7420: After changing the toner
Just need to clean up all glasses with alcohol and move the blue panel to clean the drum, after that sould be fine.
Posted on May 22, 2009
ctnozil
  • 270 Answers
SOURCE: How to clean the print head - Brother MFC-685CW Inkjet Printer?
Replace the printhead !
Posted on Dec 11, 2009
How to repair head laser brother 7360
you do not repair them-- just replace
you can reset the error code if needed
Feb 16, 2015 | Brother MFC 7360N - Multifunction fax /...
Why is my Brother MFC-7630N displaying an "insufficient memory" when I try to scan?
Try scanning at a lower DPI setting. The machine is only rated to a certain DPI which is how much information it can handle per inch. Lower the DPI the more pixilated an image you get becomes when blown up but unless you are planning on printing 6/4 photos in A3 size then 600-1200 DPI is plenty.
Sep 06, 2014 | Brother MFC Office Equipment & Supplies
Why does my Brother MFC-7360n Does Not Pick up paper?
Leave the machine and attend to it at a later time repeating all you initially did.
Aug 28, 2014 | Brother MFC 7360N - Multifunction fax /...
Why brother mfc 7360n printing envelopes wrinkle paper
Do U mean wrinkle the envelopes?,,,,I can solve some MFC-9840-CDW issues, but the 7369N is a guess. Read your manual or do a google search.....There maybe a setting in the 7360N that adjusts printing for card stock and envelopes....
Jul 01, 2014 | Brother MFC-9840CDW Laser Printer
Brother manual feed insert paper
I am a Brother employee working for the software technical support department.
We have a solution for your printing issue posted on our solution site.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000016347
Description of Problem 100000012720
When I try to print from Microsoft Word or another program, I receive a message stating: Manual Feed, No Paper, or Load Paper XX. What can I do?
Brother Software Technical Support
Jun 29, 2014 | Brother MFC 7360N - Multifunction fax /...
Outlook won't print to Brother MFC7360N AllInOne Laser Printer
Must be set on Brother MFC-7360N series. Set on PC-FAX will not print with all programs, as it is printing with an output through the fax. Go to control panel, select devices, printers to change to pc-7360 series. This should print on all programs.
Mar 17, 2014 | Brother HL-5240 Laser Printer
Printer wont come out of sleep mode
Problem with your Patch Cable - Router or Switch. Last case...faulty Main PCB
Feb 27, 2014 | Brother mfc-7360n Mfc-7360n Monochrome...
Brother mfc-7360n Toner low reset
just change the cartridge or refill it again with the proper toner,else u have fault at the toner sensor or the toner itself,else u have no connection between the cartridge and the M/C DC controller, else your M/C DC controller faulty
Jan 06, 2012 | Brother MFC7360N AllInOne Laser Printer
Brother MFC-7820N Laser Printer Logo
97 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
