My hot tub i dont no how too turn it on or turn the heat up
There should be an independent circuit breaker to control the tub, most commonly a 50 amp GFCI breaker. (Has a "test" button on the breaker itself) It is usually located either in the vicinity of the spa in a gray box, or in the main circuit breaker panel of your home. In rare instances, they may have used a "fuseless disconnect" either in the spa equipment compartment, or within the vicinity of the spa. (at least 6 ft. away from spa) The disconnect is simply a removable lever that you pull out to disconnect power to spa. I would advise you search for a breaker or disconnect. If you locate the breaker, switch it off, then back on. If you locate a disconnect, pull it out, ensure that it is inserted in the correct way, then re-connect it. If that doesn't work, check for a GFI on the equipment pack itself. It would have a "test" and "reset" button on it. Press the test, then reset button. You should hear a distinct "click" when the test button is pressed, and the reset button should stay in once pressed after that. If it does test and reset properly and the pump, etc doesn't work, then you have a problem in the control pack. (Either a fuse, or a component that an average consumer cannot diagnose or repair.) That being the case, you should call a qualified spa technician. Hope this helps.
