Most likely problems: Wrong sensor set in the media type area. Gap, Reflective. If the incorrect meday sensor is set, the unit will give a TOF error. If you hae pressed the feed button and kept pressed for at least 4 labels, and it does not automatically calibrate, check the type of sensor. If you still get error, and the correct sensor is set, do a complete calibration.
You can downlad the user manual at Datamax-ONeil Web site.
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash.
You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
The Datamax I4308 returns a position fault error if it cannot sense the label gap where its supposed to be, or if the sensor returns a value outside the permitted range. Re-calibrate to correct the error.
El controlador de Seagull es muy bueno y con muchos parametros, intenta modificar los parametros del spooler.
Seagull driver is very good and with many parameters, try to modify the parameters of the spooler.
buscar
Perhaps the sensor is out of position, you must move to the left. Also check that the hole senser is not blocked.
Also verified that the sensor type (gap or black mark) in the software is correct.
