Question about Whirlpool Duet Steam 4.1 Cu. Ft. Front Loading Washer - WFW86HEBW
Why will the washing machine door not unlock?
Whirlpool Duet WFW86HEBW front load washing machine 4.1 cu. ft.
Posted by Kay Pettit on
Lorenzo Lynn
    New Friend:
  • 32 Answers
Sounds like you have a broken door lock, or a wire harness is loose or disconnected. Also make sure the door seal is not out of place.
Posted on May 02, 2014
2 Related Answers
Willam T
  • 17 Answers
SOURCE: What is the cu. ft of my Whirlpool duet washing ma...
3.7 CUFT
Posted on Aug 11, 2010
Dennis Luis
  • 21 Answers
SOURCE: the control lock is on; on my Whirlpool Duet front load washing machine and I can't get it off
Try unplugging to reset power , to your machine..it might work..
Posted on Oct 02, 2012
Whirlpool Duet front load Washer Model WFW72HEDW error code E1/F3 will not drain or unlock
Unplug for 5 minutes then plug back in. This may reset code. You may have to push cancel / pause button for 3-5 seconds. If this doesn’t help, drain pump may have something obstructing it or may be defective
Oct 06, 2018 | Whirlpool Washing Machines
How do i get door to unlock?
Unplug the washer, wait for 15 seconds or so, plug back in and hit power button the cancel. this should unlock the door as it should reset. Do you have any fault code on your display? Is there a dryer stacked on the unit? Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 17, 2016 | Whirlpool WFW72HEDW WFW72HEDW 4.2 Cu. Ft....
Fornt load door wont unlock, Washer wont run
First unplug the machine, then to unlock the door manually you need to remove the panel under the door (three screws at bottom of machine) then reach inside by the door lock, there will be a plastic tab hanging down. Pull that tab down and the door should unlock. As for not running, when you plug the machine back in you should get an error code and knowing what that error code is will help in troubleshooting the No Run problem. Good luck.
Feb 23, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
WHAT IS THE CAPACITY SIZE OF MY WHIRLPOOL DUET WASHER MODEL NUMBER GHW9100LW2?
3.8 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 05, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
F dl symbol - my door is now locked as well
HOLD THE CANCEL BUTTON FOR 10 SECONDS IF DOESNT WORK UNPLUG WASHER FOR 30 SECONDS PLUG BACK IN SHOULD RESET THE WASHER AND UNLOCK
Apr 27, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet Steam 4.1 Cu. Ft. Front Loading Washer - WFW86HEBW Logo
210 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
