Ipod is charging while sitting in dock but won't play...keeps saying checking ipod connection...system is just over a year old and has played fine until now
ok...took my ipod and tried to feed thru the headphone jack and it didn't work BUT when i unplugged it started to play normally...YAY!!!ok...took my ipod and tried to feed thru the headphone jack and it didn't work BUT when i unplugged it started to play normally...YAY!!!
You can't post conmments that contain an email address.
Check the pins on the inside of the Ipod and the dock. It could be making contact with the power pins but not the send receive pins. Small pin will help you bend these out gently to make contact again.
ipod touch has a light piece of plastic on bottom where it connects to the dock youtube has a video on how to remove it softly with a razor blade and once it is removed it will work properly although to be played through stereo i must have my ipod touch 4th gen on airplane mode
Please check the iPod connector on the Sony. If you can wiggle it, it is
probably a bad connection. These model Sony radios have the connector
directly soldered on a PCB and it tends to get loose after a while due
to connecting/disconnecting the iPod. If it is loose, the connector
needs to be re-soldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
If it is a different model iPod then it is likely the Bose dock does not support the newer model. Quite often changes such as from iPhone 3 to iPhone 4, Bose had to release a new dock. The speakers and music will still always work, but the support will be limited for charging. Unfortunately you will not be able to fix this, other than upgrade the dock, or go back to your old ipod.
well your lucky the dock gave up the ghost before your ipod. it's possible there is some damage to your ipod also but those docks will fry your ipod toot sweet. I would not use the dock at all but if you are i would first try hooking your ipod up to a computer with a usb just to make sure it's not damaged in the charging port.
if you have a RCA jack in the dock you can use that, but the ipod is not made to play through the charging port, the docks are an after thought and I am not sure why but possibly incorrect voltage or voltage surges, but i have replaced at least 30 motherboards of customers who played them on docks. your ipod wouldn't by chance be a 30gb video or a 3rd gen nano? seems those are the 2 most susceptible to this issue.
My Warning: if it still plays music leave it off the dock
Some speaker systems which are only compatible for charging the ipod nanos and classics do not work with the iPod Touch and the iPhone, the internals are slighly different from one another which will not allow that speaker system to charge your iTouch.
To play & Charge your touch, i suggest getting a speaker system that supports the iPod touch platform.
I just had this exact problem. I'm using an ipod mini. I solved it by docking the ipod firmly at the angle the dock is at and have the ipod at an angle, not flat. I put the plastic and rubber adapter for the mini as instructed and also placed the rubber adapter for the nano upside down to keep the ipod propped at an angle. (Also can use something similar to keep ipod propped up at an angle) Took a while when I first used to figure out how the dock worked. The dock is a little weird how it is hinged to go from an angle to flat. Nothing in the instructions about this. By putting the ipod flat it would still have a connection to charge and play but the power shuts off every 10 minutes. I spent a whole night having it shut off every 10 minutes. This drives me crazy when systems have features like that which always seems to cause more problems (just my humble opinion) By having the ipod at an angle I'm currently just now having it run an hour and 20 minutes and counting with no shut offs,(fingers crossed) but so far so good. Saw on the internet that if the ipod is not connected firmly the system has an auto shut down. I think the ipod's weight propped at an angle keeps the connection firm. Also some said they want to see the ipod display, there you go!!!! This seems to be working so far for me, may be worth a try...I was about to return mine but I love the sound so I'm keeping mine now!!!! Works fine. Happy camper again. Please reply if this works for anyone it worked for me.
the pins seem fine...
