When using the foot control the bed w raise all the way up and lock into position. When lower the bed and getting to about half way and stopping the bed continues to lower to the lowest position and won't stop the mid position. What do I need to do to fix this problem? Thank you
If I remember correctly, that table uses an electric motor for the elevation. There are 2 possible problems. Either the down switch is sticking and the motor continues to run in the down position until it reaches its lowest point and hits the cut off switch or your electric motor needs a new brake installed. The brake installs between the motor and the actuator housing. These come apart fairly easily. For more information, or parts, call Pivotal Health Solutions @ 800-743-7738. I believe they are now the manufacturers of this table. Talk qith Quincey in parts.
