SOURCE: Machine is skipping stitches
First be sure you have a new needle in. A dull needle will cause this.
Also a burr from the needle having hit in the slot of the needle plate can catch the thread occasionally as well as a burr on the hook behind the bobbincase. With some very fine crocus paper or what is called a green stick these burrs need to be polished off. Or have them replaced. Check everywhere the thread touches. Otherwise it may be the timing is slightly off.
SOURCE: will only sew zig zag, even though the dial shows
Check the stitch width dial and see if your model requires the setting be at zero for a straight stitch.
SOURCE: cannot get the tension right. thread tension is
usually 3 or 4 is good on the thread tension dial
SOURCE: New home 692 sewing machine will not sew zig zag even with knobs in correct position, any clues?
the cam or gear that controls the zig zag could be damaged or
worn, I suggest the machine be checked
