Question about Texas Instruments TI-30XA Calculator
Trouble seeing the number - Texas Instruments TI-30XA Calculator
Posted by albertmcmillan on
k24674
  • Texas Instru... Master
  • 8,091 Answers
If it is the solar version, expose the face of the calculator to direct sunlight or to a lamp. For the battery version, replace the battery. If that does not work, calculator may be at the end of its useful life.
Posted on Apr 30, 2014
Engine Misfire
Here's a link to your code problem,P0300 is their's a misfire and every number after 300,like 301 means cylinder one,which this is for both of your codes,go down the list and see if it's your problem.These codes have many faults,have to trouble shoot to fix. P0301 OBD II Trouble Code Here's the P0303 code. P0303 OBD II Trouble Code
Jun 22, 2015 | Saturn Cars & Trucks
Where do I trouble shoot
I see your problem, I can't find it on line either.
Below is a link to sears parts direct. After the screen loads there is a blue box to enter the model number. In the bottom border of the blue box is a line that says "Can't find your model number? Use our finder.V" Click on it. After selecting your product it will show you locations for model numbers.
Hopefully the model number that you have is for some part of the stove instead of the actual model number. If not at some time a popup should come up offering online assistance. There is also a phone number. 1-800-252-1698 with active hours listed below it. All in the central time zone.
I live near Columbus Ohio. I don't know if Canada Sears is any different than here or not. If you can get a model number to work there are parts diagrams, parts lists with prices, Users manuals and in some cases trouble shooting guides. All I can do now is offer you good luck.
Tom
Sep 13, 2014 | Ovens
DSC LCD5511 System troulbe nr. 1
system trouble can mean that you might have a faulty expander somewhere. an expander is used to extend the zones on your current system. if not you might have a faulty pacife connected to the system go around all the pacifes and check if the red light comes on. if not replace it.
Jul 08, 2013 | DSC LCD5511 Sixtyfour Zone Fixed Message...
What do the plus and minus numbers mean on eye prescriptions? I have a minus 2 number in one eye and minus 2.5 in the other and I have no idea what that means.
Basically the numbers are an indication of your vision level. Minus numbers refer to being nearsighted (also known as short sighted). Plus numbers are far sighted (also known as long sighted).
So if you have a minus number it means that you have trouble seeing things in the distance but can probably see things that are close to you without any problems.
Feb 13, 2013 | Health & Beauty
Replace key
Take the vin number to the closest chevy dealer and the can make you a new key. The vin number is located on the drivers side of the car on the dash you can see it behind the winshield. This will fix your troubles.
Nov 25, 2012 | 1999 Chevrolet Malibu
Speed stays at 16.6 no matter what number you select
Dear Sir:
You have trouble with your sensor speed need to adjustment.
Run the calibration software for easy diagnose and troubleshooting
Otherwise see my personal TIPS, for diagnose
Trouble.
sincerely, God bless you.
ernesto a cuadra
managua, nicaragua c.a
Mar 05, 2012 | Proform 350 Treadmill Walking Belt
99 dodge ram showing trouble code for number 2 cylinder misfire and the trouble code for number 8 injector circit what is wrong
the misfire on cylinder 2 may just be a fouled spark plug.on the number 8 injector circut try useing a ohm meter to see if the injector is bad.clear the codes and see if they return
Jan 21, 2011 | Dodge Ram Cars & Trucks
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . [email protected]
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
I forgot my phone number for my phone but i got my simcard number for my pre-paid phone.
This is too simple trouble dear. you can just call your another phone or your friend phone. when you see number at that mobile screen that is your number. just save your number.
Nov 30, 2009 | Nokia 3100
Texas Instruments TI-30XA Calculator Logo
44 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Scoee Scoffer
Edward Easley
Edward Easley
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
