Question about UTStarcom Blitz Cell Phone
UTStarcom Blitz TXT8010 screen fix - UTStarcom Blitz Cell Phone
1 Related Answer
angel dust
  • 240 Answers
SOURCE: Battery is inserted but my phone says otherwise...
Take the battery out again and clean the contacts. Make sure that none of the contacts in the phone where it connects to the battery are stuck in. Ensure your battery is replaced correctly-I hate to admit Ive put mine in wrong in a hurry a couple of times!
Posted on Jun 15, 2009
I dropped it and now it won't turn on
it could also be loose wiring after you have dropped it, either way someone definitely needs to open it up and take a look
Apr 27, 2014 | Verizon Wireless PCD Blitz TXT8010 -...
My Verizon Blitz won't connect to my computer
Endless hours were spent trying to connect my Motorola Razr to my computer. This finally worked:
Go to Google Playstore on the phone. Download Motorola PIM (all upper case).
If you have an extended battery case/charger on the phone, remove the phone and insert the USB cable into the port on the top of the phone.
Or
Download "Airdroid" and connect wirelessly.
Nov 02, 2013 | Verizon Wireless PCD Blitz TXT8010 -...
Fix screen
screen still black / white it's not a screen problam .
it's belt problam
change your belt of cell who connect your slider to your keypad
that belt.
Jun 23, 2013 | UTStarcom Blitz Cell Phone
I plugged in my phone but it will not charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 04, 2012 | Verizon Wireless PCD Blitz TXT8010 -...
UNLOCK
Hi,The best and only way to get the unlock code for your pantech,is to contact the service provider who sold the phone to you and request for the unlock code,however,they might be asking some funny questions,just tell them you are travelling to a country where they are not situated and you need to use the phone when you get there,afterwards the code will be given to you for free.so easy.
Thanks and take care
Apr 16, 2010 | UTStarcom Blitz Cell Phone
My blitz works but the screen is completely black. Advice?
your screen probably died it happened to me had to get new one
Feb 27, 2010 | UTStarcom Blitz Cell Phone
My blitz screen has gone black -- phone still works just can't see anything --what do I do
if its turning on then try reset on factory settings. else get the firmware (flash) reinstalled.
Feb 20, 2010 | UTStarcom Blitz Cell Phone
When i slide down the blitz phone the screen goes off, and i can't use the phone until i slide it up, whats wrong?
it could be a setting in the display. Go to menu, settings and tools and then display settings. See if the backlight setting is on or if there is a "slide" setting to be changed.
Nov 13, 2009 | UTStarcom Blitz Cell Phone
Jun 15, 2009 | UTStarcom Blitz Cell Phone
UTStarcom Blitz Cell Phone Logo
47 people viewed this question
Top UTStarcom Cell Phones Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Tafi Nami
Tafi Nami
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
