Question about Oregon Scientific Wireless IndoorOutdoor Thermometer with Atomic Clock Sync
Cable Free In/Out Thermometer 433 MHZ tl-600
Channels wont set
Posted by tj anderson on
Looking to find the frequenecies of the upper and lower channels
  • Hi I can help.
  • For the Grant 40 channel CB there are 40 frequencies I will list below.
  • When you refer to the upper and lower channels for this raidio you must mean USB (Upper Side Band) and LSB (lower side band).
  • This is called single side band modulation which is to say the the carrier is removed from the upper or lower sideband depending on which your pick and the signal goes farther on less power.
  • So the upper and lower side bands are the same frequency just upper side band or lower sideband.
  1. 26.965 MHz 21. 27.215 MHz
  2. 26.975 MHz 22. 27.225 MHz
  3. 26.985 MHz 23. 27.255 MHz
  4. 27.005 MHz 24. 27.235 MHz
  5. 27.015 MHz 25. 27.245 MHz
  6. 27.025 MHz 26. 27.265 MHz
  7. 27.035 MHz 27. 27.275 MHz
  8. 27.055 MHz 28. 27.285 MHz
  9. 27.065 MHz 29. 27.295 MHz
  10. 27.075 MHz 30. 27.305 MHz
  11. 27.085 MHz 31. 27.315 MHz
  12. 27.105 MHz 32. 27.325 MHz
  13. 27.115 MHz 33. 27.335 MHz
  14. 27.125 MHz 34. 27.345 MHz
  15. 27.135 MHz 35. 27.355 MHz
  16. 27.155 MHz 36. 27.365 MHz
  17. 27.165 MHz 37. 27.375 MHz
  18. 27.175 MHz 38. 27.385 MHz
  19. 27.185 MHz 39. 27.395 MHz
  20. 27.205 MHz 40. 27.405 MHz.
  • If you have any comment please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 29, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
What is the max dual channel ram i can put iin my msi 865pe neo2 motherboard.
Hi merlin_65,
Regardin your question:
• Supports four unbuffered DIMM of 2.5V DDR DRAM.
• Supports up to 4GB memory size without ECC.
• Supports Dual channel DDR266/333/400/433/466/500/533 MHz and up. (DDR433/466/500/533 are overclocking spec).
Hope this helps.
Feb 22, 2011 | MSI : 865PE Neo2 (Platinum Edition)...
I can't retune the channels on my motorola xtn
Sorry, but the XTN446 has only the 8 channels pre-programmed by the manufacturer.
Channels 8
Codes 121
Frequencies 446.00625 MHz
446.01875 MHz
446.03125 MHz
446.04375 MHz
446.05625 MHz
446.06875 MHz
446.08125 MHz
446.09375 MHz
Here is a copy of the spec sheet: http://www.comm-spec.com/pdfs/radios/Motorola-XTN446-UHF-License-Free-100225.pdf
Best regards.
Mar 27, 2010 | Motorola XTN 2-Way Radio
Lost Rf tech 433 mhz weather centre's outdoor sensor
I have a RF-tech 433 MHz transmitter for sale, $25.00 includes shipping.
[email protected]
Jan 06, 2009 | Computers & Internet
Motherboard processor support
Processor Family Processor Speed System Bus Frequency Cache Size BIOS Version Notes Pentium® III processor 850 MHz 100 MHz 256 KB P14 or greater The following board revisions (AA numbers) support these processors: 754552-200 or later
754558-200 or later
A01450-200 or later.
See the board revision note, below, for an explanation.
800 MHz 100 MHz 256 KB P14 or greater 750 MHz 100 MHz 256 KB P14 or greater 700 MHz 100 MHz 256 KB P14 or greater 650 MHz 100 MHz 256 KB P14 or greater 600E MHz 100 MHz 256 KB P14 or greater 550E MHz 100 MHz 256 KB P14 or greater 600 MHz 100 MHz 512 KB P12 or greater All board revisions support these processors 550 MHz 100 MHz 512 KB P07 or greater 500 MHz 100 MHz 512 KB P07 or greater 450 MHz 100 MHz 512 KB P07 or greater Pentium® II processor 450 MHz 100 MHz 512 KB P01 or greater 400 MHz 100 MHz 512 KB P01 or greater 350 MHz 100 MHz 512 KB P01 or greater 333 MHz 66 MHz 512 KB P01 or greater 300 MHz 66 MHz 512 KB P01 or greater 266 MHz 66 MHz 512 KB P01 or greater 233 MHz 66 MHz 512 KB P01 or greater Intel® Celeron® processor 433 MHz 66 MHz 128 KB P01 or greater 400 MHz 66 MHz 128 KB P01 or greater 366 MHz 66 MHz 128 KB P01 or greater 333 MHz 66 MHz 128 KB P01 or greater 300A MHz 66 MHz 128 KB P01 or greater 300 MHz 66 MHz 0 KB P01 or greater 266 MHz 66 MHz 0 KB P01 or greateri hope that this solved your request.
Sergio
Mar 13, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Diagram of motherboard wanted
Based on your post/description, you would want to do 2 things: 1) upgrade a Cyrix and 2) install LAN capability.
#2 is easier, all you need is a PCI LAN card with the right drivers for your operating system and you should be set to go;
#1 is trickier...
If you are referring to a Cyrix MediaGXm motherboard, at most that you can go up to is a 300 MHz CPU and hopefully a max of 256Mb of memory depending on the motherboard version.
If you are referring to a Cyrix MII-433 processor which ran at 300 MHz (100x3), hopefully you can try replacing the processor with an AMD K6-2 500 or higher, that is of course assuming that the motherboard is compatible (FSB, VCore voltage, multiplier). You should take into consideration that other than the MII-433. most Cyrix CPUs run at 83 MHz bus in a (Super) Socket 7 motherboard and technically is extremely overclocked (PCI bus running at 41.5 MHz). You should meticulously check the various jumper settings to accommodate your upgrade CPU. For stability, perhaps you should choose an Intel 266 with MMX, for speed AMD K6-2 500. This is of course if you can still locate such processors and appropriate memories.
Good luck and kind regards.
Nov 01, 2007 | Computers & Internet
Temperature Transmitter
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
Programming channels
Hello ... IF YOU HAVE A COMPUTER YOU CAN MAKE PROGREMING, DETETINMG AND TRUNKING A BREEZE. IF NOT I FOUND THAT ALL FIRE AND POLICE TRUNKING ACTIVITIES ARE BETWEEN 840.0000 through 900.0000. WHEN YOU WANT TO SAVE A CHANEL TURN OFF RADIO AND TURN BACK ON SELECT THE DESIRED CHANNEL YOU WANT. THEN PRESS "PGM" AND ENTER YOUR FREQERNCY... PRESS ENTER AND IF YOU WANT TO ADD ANOTHER CAHANNEL ... HIT "PGM" AGAIN AND FREQ. AND ENTER. YOU CAN KEEP DOING THIS TILL YOUR DONE GROGRAMING .. THEN JUST HIT SCAN AND IT WILL SCAN ALL THE FREQ.S YOU HAVE ENTERED. HERE IS A SOFTWARE PROGRAM THAT CAN LOOK UP ALL FRQ ANYWHERE IN THE US AND WITHE A PLUGIN DOWN LOAD ALL THE CHANNELS. BuTel software home page ARC-433 software for Radioshack PRO-433 / PRO-528 / PRO-2051 'ARC433 is now available!' -------------------------------------------------------------------------------- ARC433 (US$ 29.95) is dedicated software for the RadioShack PRO433, PRO528 and PRO-2051 and is the most versatile software available for the Radio-shack PRO-433 / PRO-528 / PRo-2051. Screenshot from our memory editor: the most versatile memory editor available on the market: -------------------------------------------------------------------------------- Overview of options in ARC433: Order ARC433 now online using PayPal/credit card or call Santa at 1-800-SCANNER ARC433 supports the Radioshack PRO433, PRO528 and PRO2051 models in one single software package. ARC433 includes THE most versatile memory editor available on the market. Radioreference.com import option for conventional and trunk systems! Programming your scanner was never this easy! Enhanced CSV file import and 'mapper' Paste Frequencies DIRECTLY from any website using 'Paste Special' Setup channels in an easy, spreadsheet type interface. User Manual (45 pages, PDF file) Store Unlimited number of configurations on your harddisk. Copy/Move/Swap memory banks / memory channels Compatible with Windows 2000 / XP. All updates are free for registered users Easy cut/copy/paste data between channels and banks. Move channels up and down with quick move buttons Export CSV data Fill down/series option Full clipboard support for import/export data to/from other applications Easy data toggle with mouse double click or space bar or keyboard shortcuts Sort frequencies per bank Remove duplicate frequencies Easy Fill for setting up new banks in a few seconds (enter a start frequency and a step, and easyfill will calculate and fill the selected bank) Extra Dummy bank for storing temporary data while you are re-organizing your scanner channels. Print option System Requirements: Windows XP/2000/Vista PC interface cable 20-047 for USB or PC interface cable 20-289 for serial port Use other cables at your own risk! Use the ARC433 demo version to verify communication works before purchasing the software! All software sales are final. Order ARC433 for PRO 433 / 528 now online using PayPal or a credit card or call 1-800-SCANNER. -------------------------------------------------------------------------------- Screenshots:
Apr 16, 2007 | Radio Shack Pro-95 Handheld Scanner
Oregon Scientific Wireless IndoorOutdoor Thermometer with Atomic Clock Sync Logo
147 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
