Canon imageRUNNER 8500 Copier Logo
Question about Canon imageRUNNER 8500 Copier
E0004 code error - Canon imageRUNNER 8500 Copier
2 Related Answers
checkitright
CheckitRight
  • 1363 Answers
SOURCE: E0004 on Canon NP6050
it is a SSR,heater 1 or 2 ,or thermal switch error.   Try to reset,        follow this procedure. SERVICE MODE E004 SSR O FUSER WON´T SHUT OFF
To reset this code use simulation 401
SERVICE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck     CE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck
Posted on Oct 24, 2007
Sunil Rathod
  • 199 Answers
SOURCE: I am getting an error code E0004 on my np8530 copier
there are a motor sensor does not work properly
Posted on May 22, 2009
Canon ir 400 error code e004
The error code E004 deals with the fixing unit. Odds are that you may have one or all of the following parts need to be replaced > the fixing lamps or thermistor or the thermal fuse or the upper fixing roller.... Just for starters... Good Luck
E0004-0001
A E0004-0001 is caused by the fuser unit... Have you lost power resently? The code will need to be reset in service mode... Good Luck
There is an error in imagerunner 6570 copier E0004-010 it is resolved then Error E00004-0103 occur. What would be the solution. What is the complaint?
press the [shutdown]key. After the machine has been shutdown turn the main power switchon the main units right side
[shutdown]
if the machine still does not operate normally contact your service representative with the error code below
E000025-0001
6570 e0004-0106
6570 e0004-0106 pls give solutions for above said problem (error code)
Apr 14, 2011 • Home
43helpful
6answers
Eror e00014 pada ir 5000, sudah dierror *28* tetapi tetap masih eror. motor pemanas tetap gak jalan gimana yaaaa? tolong dong solusinya...
bos tolong nih, kode error E00004-0010 pada mesin canon ir 6570, gimana solusinya. terimakasih sebelumnya
E0004-103
This problem is caused by the fuser unit that fuses the ink to the paper. You will need to reset the service error in the service mode before the code will be reset. The procedure for resetting the service error is in the manual but is entered by pressing the * 2+8 buttons together and then * again. Then select FUNCTION - CLEAR - ERR Then exit service and turn the machine off and on and the code should go. If not then replace the thermistor suggestedin the manual for such codes.
You can find the ir5570 service manual here.
old marine
old marine
Marvin
Marvin
