SOURCE: My galaxy tablet was fine
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
SOURCE: my samsung galexy Tablet is full charged but not responding when I try to turn it on
Does it do anything at all when you press and hold the power button? Hold the power button in for about 15 seconds. That should force it to reboot.
If you get nothing from doing that, then that usually means one of two things: either the tablet is not charged and the battery is completely depleted, or that the tablet is broken and will not boot. Try charging it with a different cable, try a different charger, or try plugging it into a PC USB port with the PC turned on. Leave it plugged in overnight. It should trickle charge that way and give you enough power to boot up.
