ZAGG New Apple Ipad 2/ Brand New Ipad Zaggfolio Wireless Bluetooth Keyboard/ Stand/ Case - Black Carbon Fiber Logo
A
Anonymous Posted on Apr 30, 2014
My backli ght stopped lighting - then the keyboard stopped. Is there a switch I may have hit?
Back light stopped working then the keyboard shut down. I fully charged my new unit a month ago and have had no problems till today. Is there a switch I may have inadvertently hit?
Paul Wang
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 173 Answers
  • Posted on Dec 22, 2015
Paul Wang
Expert
Level 2:
New Friend:
Night Owl:
Answers
173
Questions
0
Helped
27210
Points
228
Keyboard CAPS LOCK light working in reverse
whoever opened up your keyboard messed up with the light cables, open cable and see if you can put back cables in correct connections.
1helpful
No Tail lights. Or brake lights(when the headlights are on). HELP!!!
I think you have a bad ground at the back on both rear lights or their earth out on the same connection but these american cars use a funny system where the stop lights are the indicators and not a seperate yellow light like europeon motors ,Now these brake light switches also allow the indicators to work by shutting off the feed to the stop light so it flashes with indicators ,Why american cars use this system i dont know as its so complicated for the stop light switch function but try the ground or earth wire on the back lights and if no joy then ask a american mechanic with experiance of this sort of circuitry as when i get american cars for import i have to fit new back lights and disconnect the brake light switch .
Brake lights ion while im driving. had the brake relay and sensor replaced and it still ain't working
make sure the brake light switch on the brake pedal is reaching the arm, it sounds like your switch is too far back and the arm is not hitting it to shut off the lights
2helpful
I have a Microsoft wireless 3000. The mouse works I can click and move it anywhere. However my keyboard will not type any letters. It was working fine. Did I turn off the keyboard by mistake? How can I get...
Looks like the keyboard is either working on a different channel, or its batteries died. Hit the set button on the face of the wireless receiver. It will start flashing in sequence. Then hit the small button on the back of the keyboard, and one of the lights on the receiver will stop flashing. Then hit the small button on the back of the mouse, in order to synchronize it as well. If the keyboard still doesn't work, then replace the batteries.
The keyboard will not do anything.The lights on the far right all lite's up and no key will work I then shut down and the keyboard will work until the sleep mode comes on and the lights are on again?
Get a new keyboard....
try shutting the PC down, remove and reconnect your keyboard then boot the PC back up.... 9 times out of 10 this will work
Asus CS5111 keyboard stopped working
Try taking the batteries out of the mouse and let the receiver find the keyboard first, then once the keyboard is found put batteries back in mouse and let the receiver find the mouse.
Eas keeps lighting
eas works with 5 valves,compressor,
compressor works?(in the box left side undernhood,)there is als interferance with dooor switch,if one door open,no position change possible,
the message on dash is eas malfunction?,
opn compressor box,if nor running compresor,shake or slight hit,
reset to 0 position?,shut contact,take off relay for compressor,disconnect wiring on compressor(main,)switch on again,now place back relay,connect again,while contact on,wait some minutes,reset is done,cut contact,on again,and see the for message,
2helpful
3answers
About the belkin 2 port kvm switch
i already have one computer hooked up to a beklin. can i hook up another
Top ZAGG Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a ZAGG Computer and Internet Expert? Answer questions, earn points and help others
