SOURCE: problem with starting the speakers
Xplode
Good day and happy holidays
you have to look at back of your comp, if you has a 5.1 speaker first, like Creative Audigy, live, or X-FI, then according with the cables, colors, must be, Green . black, according for output sound, see manual for the cables and put at back according.
SOURCE: SPEAKER FRONT RIGHT NOT WORKING?
SINCE THERE WAS NO SOUND COMING FROM THE RIGHT SPEAKER I TOOK OUT THE GREEN WIRE THAT GOES BEHIND THE COMPUTER AND PLUG IT INTO A CD PLAYER THAN I NOTICED THAT THE SOUND CARD OF MY COMPUTER WAS NOT FUNCTIONING PROPERLY SO I REPLACED THE SOUND CARD NOW IT WORKS PERFECT.
SOURCE: logitech x 540 speakers wont detect on my pc (dell inspiron 530)
Here is the DELL support page for your computer and the logitech drivers and software needed.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSP_DSKTP_D530&os=WLH&osl=en&catid=&impid=
SOURCE: New laptop. Hooked up Logitech
if your computer came with a motherboard disc the sound drivers could be on it have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
