Vacuums Logo
Question about Kirby Vacuums
I have Kirby vacuum cleaner that all of the sudden won't turn on. I know the power cord has been stepped on a few times through it's life but it doesn't appear to have been pulled enough for it to not get power to it. There were occasions, however, that I stepped on the cord while vacuuming and it would momentarilty quit working. What do you recommend I do?
Domenico Grillo
    Habit-Forming:
  • 170 Answers
Brocken switch could be the problem but power cord most likely check continuety on both wires from the plug to the unit also does have fuse have you checked?
Posted on Sep 27, 2017
5 Related Answers
Anonymous
SOURCE: kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole is...it will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
Posted on Sep 03, 2007
Anonymous
  • 112 Answers
SOURCE: Help on kirby G4D
here is a link to taking the fan off of the kirby...all the Generation Series Kirbys are the same :)
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
Hope that helps!!!
Posted on Apr 08, 2008
b0sslady2001
Marci Marple
  • 357 Answers
SOURCE: kirby shampoo instructions how to assemble shampooer
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
This is also a great place to order Kirby supplies!
Posted on Jun 22, 2008
Anonymous
  • 3 Answers
SOURCE: Power cut off after handle was dropped on floor while vacuuming
connections inside the handle came loose. happens to me all the time. take the handle apart and connect the wires back.
Posted on May 29, 2009
Anonymous
  • 231 Answers
SOURCE: Our Kirby g6 vacuum cleaner will not turn on and
you probably have a bad switch. let me know if you want me to walk you through replacing it
Posted on Jan 03, 2010
2answers
Kirby Vacuum Cleaner on/off switch won't stay switched on
If the motor turns on turns off in the course of the vacuuming, check the cord or the switch This is how you replace your cord on a Sentria vaxuum.
2answers
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
My Kirby G3 diamond series won't turn on
Hi There, The most common problem by far is that the cord is faulty. This is a pretty easy repair to do at home. If your machine was randomly cutting out before it stopped altogether then the cord is likely the culprit. If however it stopped all of a sudden with no warning then it is possibly a switch or motor issue which is a much harder repair to achieve for a novice.
The kirby cords are not terribly expensive (and I have linked a how to video showing how its done) so if you need a new one I would say DIY is the go, otherwise spend the $25 get a pro to take a look.
I was using kirby g5 and I think I stepped on cord and lost power on vacuum. Now it won't start. Could this be a damaged cord..or what?
either that, or it was pulled so hard, it came disconnected from the vac switch. stepping on a cord rarely affects power. so, check vac switch and outlet to make sure the outlet has power.
(if you know an electrician or if you feel comfortable disassembling the vac i would look at the point that the cord enters the vac and trace it to the switch looking for obvious breaks)
12helpful
How do you replace the belt on my Kirby G5 vacuum cleaner?
Hi There,
We've created a great video demonstration on how to replace the belt on Kirby generation vacuum cleaners. This will walk you through step by step on how you can replace the vacuum's belt, as well as do the basic maintenance on the roller brush to prolong the life of your belt.
I hope that this video helps you! If so, please be sure to rate my repair by clicking the 4 thumbs up icons in the top right hand corner of the repair.
Thanks again,
Chris Jones
GoVacuum.com
My Kirby vacuum cleaner will only run for a few
could be caused by bad bearings in the motor or bad carbon brushes and a worn commotator on the armature. check the cord where it connects to the top of the handle on the swivelling strain relief. usually the cord fails there .
Jan 03, 2010 • Vacuums
2helpful
My belt broke on my kirby G-5. I havent put a belt on it in 10 years. I having problems getting it on.Can u tell me the right way? Thank you.
Greetings,
I recorded a video repair of replacing the belt for the Kirby generation vacuum cleaner. The following video will walk you through step by step on how to replace your Kirby belt, as well as doing some basic maintenance to the roller brush to prolong the life of your belt as long as possible.
How to Replace the belt on a Kirby Ultimate G Vacuum Cleaner;
I hope that this video was helpful to you in repairing your Kirby. If you found the video to be helpful, please kindly rate the video helpful by clicking on the Thumbs Up Icon below.
Thanks for watching!
Chris J.
5helpful
2answers
How do you attach the belt for the roller-brush on a Kirby Generation 3, up-right vacuum-cleaner?
Greetings,
Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
Chris J.
Top Kirby Vacuums Experts
David Shaub
Paul Bade
W.L.
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
