Question about Arcsoft TotalMedia
Arcsoft webcam comapnion 4 activation code - Arcsoft TotalMedia
I cannot find my ArcSoft Total Media Extreme activation code
1. Click the Windows Start button (on the bottom left corner of your desktop on the TaskBar).
2. All programs Click on ArcSoft Connect
3. "View my ArcSoft Info"
If you haven't registered your product yet:
2. Select All programs -> ArcSoft Connect -> Start ArcSoft Connect
3. A pop-up window will display on the bottom of your screen .
4. Once highlighted, Click on the arrows to the right of the text.
5. Then click on "Register my ArcSoft Products"
Nov 22, 2017 | Arcsoft Computers & Internet
Need activation code serial number
The activation code (5 blocks of 4 number/letter combinations ) would be on the case --on the disc on on the box the cd came in. If you do not have the box or case still then contact the program provider and seek support to get it
Aug 01, 2013 | ArcSoft Print Creations
Cannot find the arcsoft webcam companion 4 icon to turn on the webcam
Open Start Menu, in the Search box, type Arcsoft, if the software is in the system, it should come up. If the drivers/software for the webcam is installed, Open Control Panel, Device Manager, Imaging Devices, you will find it there. If not, re-install the software that came with it. Arcsoft support: http://www.arcsoft.com/webcam-companion/
Feb 08, 2013 | Computers & Internet
How can i recover my accidently deleted arcsoft webcam software
There is software out that will recover deleted files, try download.com and type recovery you will be presented with a list to choose from.
Mar 11, 2012 | Cameras
How do i access my Sony vaio webcam
Sony's Vaio laptop computer line includes the company's Motion Eye webcam and ArcSoft WebCam Companion software for Vista and Windows 7 operating systems. Located in the LCD screen's upper bezel, the webcam is positioned at face-level when seated at the computer and automatically tracks movement to keep subjects within the lens's field of view.
1.Click on the "Start" menu at the bottom left corner of your screen, choose "All Programs" at the bottom of the menu just above the search box.
2.Scroll through the program list until "ArcSoft WebCam Companion" is located. Alternatively, you may type "WebCam Companion" in the search box to locate the program.
3.Click on the WebCam Companion icon to open the program. The program window will open, offering choices of Capture, Record, Monitor and Edit. Capture is used to take still pictures individually or in a series, Record is used to record videos, Monitor records videos when motion is detected and Edit allows editing of previously recorded videos.
4.Choose the webcam function you wish to use by clicking the icon. The appropriate screen will open, activating the webcam and displaying the camera view on-screen. The on-screen view will display what is within the field of the webcam lens, allowing you to adjust the LCD screen or your position before beginning webcam functions.
5.Click the webcam function according to the mode you have chosen. Functions in Capture mode include Capture or Burst, Record in the Record mode, Monitor in the Monitor mode and Snap Shot or Edit Video in Edit mode. When you have completed your webcam activity, the program automatically saves your video or snap shot within the program to be accessed, viewed or edited at a later time.
I hope you find it very helpful. Thank you for using fixya.com
Aug 20, 2011 | Computers & Internet
I have no msi A6200 webcam driver & I can't video chat.Please solve my problem. Thanks-
Hi you could try pressing the FN+F6 keys at the same time this may activate the webcam for you
if it does not try this
HOPEFULLY TO INSTALL WEBCAM
START
ALL PROGRAMS
ARCSOFT WEBCAM COMPANAIN
LAUNCH UTILITY ARCSOFT WEBCAM
INSTALLING WEBCAM AND SOFTWARE?
THEN YOU SHOULD SEE DRIVER SOFTWARE
INSTALLED CORRECTLY
good luck
Apr 08, 2011 | MSI A6200-059US Laptop
How to install msi cr400 webcam
Hi
try FN+F6 key to see if you can activate it
if not
try this
START
ALL PROGRAMS
INSTALLED CORRECTLY
NOW GO BACK TO
START
ALL PROGRAMS
ARCSOFT WEBCAM COMPANIAN 3?
NOW HIGHLIGHT THE WEBCAM COMPANION 3 ( WITH PICTURE OF WEBCAM )
RIGHT CLICK IT AND GO TO SEND TO
THEN SEND IT TO THE DESKTOP ( CREATE SHORTCUT )
IT SHOULD THEN ON DESKTOP FOR FUTURE EASY USE TO TAKE SNAPSHOTS
SO THEN CLICK ON IT AND GO TO CAPTURE THEN YOU CAN TAKE YOUR SNAPSHOTS
WHICH WILL BE SAVED IN YOUR DOCUMENTS UNDER WEBCAM MEDIA
IF YOU GO OVER TO THE LEFT HAND SIDE OF THE CAPTURE BOX
AND GO UP TOP TO CLICK ONTHE CAPTURES BOX IT WILL OPEN AND SHOW YOU THE PICTURES
THAT YOU HAVE TAKEN
AND IF YOU GO DOWN TO THE BOTTOM LEFT
IT WILL GIVE YOU OPTIONS OF DELETING PRINTING EMAILING
& FIND TARGET WHICH IS WHERE THE PICS ARE STORED
GOOD LUCK
Mar 25, 2011 | Computers & Internet
I cant find my webcam programme in the system.i cant start the webca itself.
The Sony Notebook computers are shipped either with the Arcsoft WebCam Companion or the VAIO Camera Capture Utility.
1. Click on start, in the search bar type, Webcam Companion or VAIO Camera Capture Utility to find what is shipped.
2. If both are missing, then check if the drivers are installed for teh camera in device manager.
Press the Windows logo+R keys together to open Run Window.
3. In the Run Window, type "devmgmt.msc" without quotes and press the enter key.
4. In the device manager window, check if Imaging Devices is listed and has the Sony Visual Communication Camera driver installed.
5. If that is missing then, install the respictive software i.e; Webcam Comapnion or the Visual communination driver and camera capture utility.
You can install the drivers from the Sony support home page.
I could have provided the link if there would have been the exact model # of the notebook provided by you.
However, if the software is installed, then follow the steps to use the cam with VAIO Camera Capture Utility from the below link.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1000555
To use the cam with WebCam Companion Software follow the steps from the below provided link:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1015371
Feb 05, 2011 | Sony VAIO Notebook
Computers & Internet Logo
498 people viewed this question
Top Arcsoft Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you an Arcsoft Computer and Internet Expert? Answer questions, earn points and help others
