Samsung ML 2010 Laser Printer Logo
Question about Samsung ML 2010 Laser Printer
My samsung ml-1666 printer problem is while i'm push the power on button the printer LED (RED & Green) lite goes on and its consist continue. what couse this problem.....
My samsung ml-1666 printer problem is while i'm push the power on button the printer LED (RED & Green) lite goes on and its consist continue. what couse this problem.....and neither its working nor its geting turn off i have to put out the power cord to switch off the printer
Posted by Vinod Kumar on
John Ray
  • 790 Answers
Two reasons I could think of
Low toner.
Pre-set counter on cartridge reaches limit.
Try removing the toner cartridge and powering the unit on.
While unit is plugged in, re-install cartridge.
Not knowing how old the printer is a the amount of use, it is had to answer
Posted on Apr 30, 2014
4 Related Answers
Anonymous
SOURCE: ML-2570 Samsung printer having problem orange LED is blinking
restart than on
Posted on Jul 10, 2009
pineworks
Clive
  • 4362 Answers
SOURCE: Flashing Red & Green lights - Samsung ML 2510
Hi
It maybe one of the fuse gone.
You have to change the fuse:
The fuse is 250mAh and 3/4" inch long (20 mm) round glass with metal ends. The electrical contacts are not in the cartridge but inside the printer: There is a plastic fuse holder on the cartridge, even the starter cartridge. You just simply pop it into the holder. This will stop the flashing red LED and the system tray will say the cartridge is full.
All The Best: Pineworks
Posted on Jan 30, 2010
Anonymous
  • 4 Answers
SOURCE: my samsung ml 2570 Printer Green & red LED
pls check formater boaed& fuser asmbleay
Posted on Aug 02, 2010
Anonymous
SOURCE: firmware of ml 1666
need for samsung ml 1666 chipre set software
Posted on Aug 23, 2012
Do not my printer initialize & red light glow
LP-365W On Line LED Is Solid Red - samsung product ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsImportant: Before you perform any type of service on your printer that requires you to... Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ElectronicsDec 2, 2014 - Important: Before you perform any type of service on your printer that ...Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ML-3561N Laser Printer Initialize - Questions - Fixya
www.fixya.com > ... > Samsung > ML > Samsung ML-3561N Laser Printer
ML-2570 Samsung printer having problem orange LED is blinking ... initializing stage green LED glows continuosly,After initializing Printer green LED turn into ... the red light remains on when i switch on the printer.. and it doesnt initialize the ...
Samsung glow plug Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > glow plug > Printers & Copiers
Printer Problems...red status light glowing I bought a Samsung CLP-310W a ...Samsung printer having problem orange LED is blinking in initializing stage ...
Reset for Samsung ML-1660 ' FixYourOwnPrinter
5helpful
Firmware of ml 1666
16helpful
2answers
RED AND YELLOW LIGHT ON SAMSUNG ML 1666 PRINTER
my samsung ml-1666 printer problem is while i'm push the power on button the printer LED (RED & Green) lite a second and goes off.what couse this problem.....
I was reset the samsung ml-1666 by using of chiprest utillity but printer is (asking )change ml-1640 insted of ml1666 what i do plz help me
Dear
You have upload the firmware of ML-1640, which is not possible. Try to upload ML-1666 firmware fix. You can also try covering a tape on the chip contact area only.
Thanks.
2answers
I am using samsung Ml 1640 Mono Laser Printer .After finishing Toner Ink I refilled it and set the toner into the printer . Then both of the lights Green & Red light is glowing but the Red light is...
Samsung uses a chip that senses when the cartridge has ended its service life, the chip is located in the cartridge itself, refilling toner won't help, replace the cartridge with a new one. hope this helps ;-)
1helpful
Reset samsung ML 1666
i was reset the samsung ml-1666 by using of chiprest utillity but printer is (asking )change ml-1640 insted of ml1666 what i do plz help me
24helpful
3answers
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Hi
Top Samsung Office Equipment & Supplies Experts
Gary
Gary
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
